I'm aware there are little things I can cover with this, but damned if I just typed it from memory. Take it or leave it.
Broadband
Apple Menu > Control Panels > TCP/IP (configure for your LAN settings)
Dial-Up
Apple Menu > Control Panels > Modems (verify the correct one is in the machine)
Apple Menu > Control Panels > TCP/IP (select PPP)
Apple Menu > Control Panels > Remote Access (setup the dialer)
Canon Rebel XTI
Google Cr-48 Beta Laptop
