alright guys, i think i have a semi-decent idea here.... i have this empty Sterilite container just sitting by my desk so i think im going to put a piece of plexiglas on the bottom make mounting brackets for the motherboard, cd-rom, and hd and have a server in a drawer, with easy access! as soon as i get the time/digital camera, ill do this and post a mod guide and does anyone have tips for cutting plexiglas?
Its best to use a jigsaw or bandsaw with a high tooth count blade (ie; metal blade) you can use a table saw or circular saw, but if you do I would use a plywood blade and put it in backwards (yes I said backwards) feed slowly and if you can adjust the blade speed down to prevent re-melt. After the cut use a blade to scrape the white fuzz off and your in buseness!
