yea, they gotta be pissed. Kinda like the guy with konfabulator and all the others
Here is my itunes6 now :P
Only problems that I see the inability to organize old videos/tv shows/movies with ease. Even my G5 stutters a little when messing around with some of these videos in itunes. It organizes all your videos inside a program called "itunes". It copies and organizes the files inside of your music/itunes/ folder. But, I would def say its a step in the right direction.
I say, rename the app, gear it to media, not music, and we will be ready to roll!
Post edited by: oojacoboo, at: 2005/10/12 16:56
Wish I had an USB IR input device and a copy of Front Row to mess with right now
Also, I tried loading some videos into iTunes 6. Within secons, my Mac mini sounded like a Harrier and I swear it started to hover. Well that parts a bit of a fib, but iTunes does not handle video like it should. You're better off loading QuickTime.
Post edited by: whitlock, at: 2005/10/12 17:30
shadow, who mentioned they had a copy? I think this was a great release, I couldn't be more pleased, although I won't buy any of it, I think everything is great. The iMac upgrade was very impressive as well! bluetooth, superdrive, frontrow, isight and lighting, remote, all standard, how can you complain? O yea, its thinner too.
This may sound stupid, but how do you copy videos into your video library in iTunes 6? I tried drag-and-drop, but the video library won't let me drop anything onto it. And I can't find a video subsection in the Music > iTunes > iTunes Library folder.
Cheers! :-) - JediJoker
