I have the white papers or repair manual in pdf for the blue&White if you like I'll email it to you
Edit: Been throught it, doesn't show pinouts for case but everything else including power supply...
Post edited by: anil8tor, at: 2005/10/09 22:06
Thanks but its a beige board, yeah, a beige board. For reasons that will be described in the article if I ever finish this thing. Thanks anyway. -maestro
Ok.......well if anyone needs them. I was all over the net looking and finnaly found them. As I have a blue & white seemed like a good idea
As you look at the board with the ports on the far ide from you:
The LED is attached to the pins at either end of its five pin connector. Red on the right. Power is the middle and right pins of its three pin connector. Red on the right again.
The connectors are both marked on the front edge of the board quite clearly.
