So I just found a fairly effective way to cut complex shapes into acrylic - sitting in a chair, I put my jigsaw on lowest speed with a metal cutting bit in, pushed down the trigger and set the lock then turned it upside down and held it between my legs - then I had 2 hands free to control the acrylic. Granted, if you happen to have one of those non-handheld jigsaws (band saws?), that would work better. So here's a picture of an apple logo I made from the left over circle from cutting blow holes in my laptop stand:
Edit: can anyone think of a use for this? All I've got so far is christmas ornament - if you have a good use for it, i'll even mail it too you.
Post edited by: soundmann18, at: 2005/09/22 21:55
12" PowerBook G4 1.33 GHz - 1.25 GB RAM 22" Acer Flat Panel ----------------------------------- Avatar: my brother's snow mobile 15 seconds after he jumped off.
Wow, that is impressive! I can't believe you did that with a jigsaw... great job! :blink: Perhaps you should invest in one of these?
As for uses: as soon as I saw that, I thought it would look great with a blue glow behind it on a chasis. Do like Maestro suggested, plug in some LED's and voila!
Post edited by: shadowboxer47, at: 2005/09/22 22:02
yeah - i borrwed a friends for some stuff around here (putting in a master switch on a 3 branch lamp, removing the white plastic in my bt mouse) but he only had a grinding stone, so it'll be fun to get a full set
Greaty work! But man watch those fingers! :unsure:
