Ok, I have 13 Cube systems that I got from a client. He got me to install 14 PCs in his office. I kept the 13 Cube systems. Anyway I striped them down and built 8 fully loaded systems. Heres the specs, each one has the same specs.
384MB RAM G4 450Mhz 20GB hard drive 4X DVD-ROM
The guy that had theses upgraded them 6 months ago and then found out the company he was contracted to used PCs and couldn't share the work. Anyway my idea for theses is to make a 8 node cluster server. So in all the whole system will have the following specs.
3072MB ram 3600Mhz (3.6GHz) 160GB drive space
Ofcorse all of them will run with out a monitor but the main system. I don't know if MacOS X support clustering so i'm going to use FreeBSD. Tomorrow im going to go buy a shelf unit for them and clear off a spot on my desk for another monitor, keyboard and mouse. If I can i'll use the airport for networking them so I won't have a mess of ethernet cable everywhere.Also i'll have to end up buying a external DVD+RW so I can back stuff up once a week with it. Sadly I won't have it here at the house. It will be in my office at work as a server. Yet I can get rid of my huge very outdated SGI Indigo R3000.
After thinking about it i'll just use Linux orBSD. Runs faster then tiger with my system configuration. I've done this in the past a few times with some clients so it will be easy to do.
Right now I have them setup in my garage and slowly working on them. Then i'll just set them up at work next week.
Rackmount cases cost way too much so i'll just use a metal shelf that has three levels. The frist two shelfs will have the Cubes and the top shelf will have my securty PC with a 21inch Dell CRT monitor for my securty cameras and i'll have a small 10inch touch screen LCD on my desk with a wireless keyboard. It will be nince when it is finished.
Maybe in the furture i'll switched to Mac OS X for my cluster.
Well my 13 node cube cluster is complete. I'm done modding for a while. I need to fix some of my systems like my iBook HD problem and reinstall Evox on my xbox.
It's used for my company called Gothicware Systems. A small simple computer repair company. The cluster will be used to run my HTTPd, FTP and email and used for other things like invertory, bills, invoices, etc etc etc...
I tryed taking a picture of it but it came out all crappy due to too much iterferince. Sometime i'll buy a one time use 35mm camera and take pics of it and get them put on a photo CD.
