Ok I just found a 20 Gig hard drive in my parts closet, So I installed it in my Blue & White. So I grabbed my old OS X 10.0 disks and started to install and up-grade to 10.2 as I have in the past. But this time after the install my mouse stops working. Works fine during install but stops after re-boot. I have done this twice! Right now I am just going with the 10.2 up-grade to see if that fixes it. Any ideas?
Post edited by: anil8tor, at: 2005/09/09 16:29
you know the B&W is a really good machine...I have no idea what could be wrong with that. It sounds like you've got some USB driver conflicts, but the USB on the B&W was built in. Is it just your mouse? Does your whole system lock up, does the keyboard stop too?
Weird, never heard of that issue before. Does switching USB ports work? Are you using the mouse off your keyboard? Also, do you still have an old ADB mouse laying around to try?
tried several mice, and both usb ports... pulled the Hard drive and stuck an apple/quantum 6 gig in. Did the install and no prblem :blink: I guess it just doesn't like the drive, seems a shame because I sure would like the space. Maybe I'll pull the zip and put the 20 there.
Yeh, I must be the last guy on the planet who uses them, but I have like a dozen disks I back up my downloads on. Don’t have a burner in my Blue... so I ordered a usb external case from Tiger to put my 20 gig in, and maybe a second one with a dvd/cdrw! whoo-huu we're talkin’ the cutting edge of obsolescence here! :woohoo:
Post edited by: anil8tor, at: 2005/09/16 21:12
you aren't the last one to use them... i still use jaz drives to transfer stuff from my 9600 to my beige g3. at one point i thought about putting a zipdrive in my g4 cube just for kicks and giggles
deviant
Thanks macDeviant, I just remembered my brother-in-law asked me a few weeks ago if I would put a 5 1/4" drive in his Dell xp machine because he has "hundreds" of disks with dos programs on them. I didn't want to spend the next week trying to configure xp to run all those dos 5 programs, so I said I would have to find a drive... must be 20 of them in my parts room :evil: but I cant seen to locate one :lol:
ok I solved the added drive problem without giving up my Zip Drive, Found this at Tiger Direct. Cheap and easy. And I can pull the Hard drive and put in a cd/dvd burner. This thing is under three Sawbucks! :woohoo:
Post edited by: anil8tor, at: 2005/09/20 19:19
You must have a rev. 1 B&W G3. I had a similar issue. The problem is that it will not take faster drives or large ones without a pci hd controller of some sort. Your usb 2.0 drive kit is a good idea, except if you are using it with the stock usb ports. It will be terribly slow. I saw a mac pci usb 2.0 card on eBay for 9 bucks, if you need one. -maestro
