How the HELL do you open up an MX900? I see no obvious way to do it. I'd like to maybe replace the red LED with laser (the expensive and awesome option) or just a blue LED (the less expensive and cool-looking option). Anyone know how to do this and where to get good but cheap parts? I'm thinking I might also paint the shell black to match future mods to my PB. screen, and speakers.
Cheers! :-) - JediJoker
I'm pretty sure that I recently read an article about those saying that you take off the little pads on the bottom and there are screws hidden under them, but I couldn't find the article, so i may be wrong
Well, yeah, that would be cool, but I can't make this thing cool and I like the way it feels in my hand. So that would be pointless for me. So, in terms of LEDs... Where should I get them?
