• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » Mods and Hacks » Desktop Mods
      » Hardware Mods » How Far Can you OC a QS 733?
Page 1 of 2 1 2 >
Topic Options
Hop to:
#460960 - 08/29/05 07:40 AM How Far Can you OC a QS 733? [Re: Medicoooo]
Loophole Offline
Hi I am new here and have seen the "simple" mod for OC a QS 733 to 800.
I was wondering how far you can push the 7450 (not sure what revision) as the multipliers go to 8x (1067Mhz). Is this stable or is it easier to buy a cpu upgrade over 1.2Ghz?
Also if my 733 doesnt have L3 Cache is it possible to add 2Mb to speed things up?
Just wondering if things like this are possible or worth doing?
Any help would be really appreciated
Regards
Loophole
Top
#460961 - 08/29/05 01:04 PM Re:How Far Can you OC a QS 733? [Re: Medicoooo]
maestro Offline
Welcome. If you do decide to oc, stick to 800. That will keep it stable and reliable. You cant add cache to the cpu. Not having it really slows it down. I would suggest you purchase a used
QS cpu or an upgrade. That will give you the most for your effort. Overclocking is not easier than changing cpus. Good luck with it and let us know what you went with.
-maestro
Post edited by: maestro, at: 2005/09/11 12:28
Top
#460962 - 09/05/05 09:09 AM Re:How Far Can you OC a QS 733? [Re: Medicoooo]
Loophole Offline
Back Again....
So I FINALLY recieved my new (well second hand ex-govt) QS 733 Today (YAY!!). I will be doing the 800 OC mod shortly (Thanx Maestro).
Anyway befor I even tested it I loaded it with a Gig of Ram and 3 IDE HD's (who need a zipdrive anyway?) 120,80 and 40 so a total of a bit over 200 Gb space. Quite a bit quicker than my G3 Imac and my now defunct Cube (reason for upgrade).
I had to drill some new mounting holes for the HD in the Zip slot but it only took about 15 mins to get em in the right places and now I have an extra 40Gb instead of 250Mb (removable)!!! I also put a piece of black ABS plastic behind the umm open slot of the zip drive its about .5-1mm thick and it makes the slot Bulge out ever so slightly cos its squashed between the metal frame and the plastic front plate but atleast it keeps little fingers out!
Next is to quiet the fans a bit (they are not that loud)
I will keep you posted with my progress, but it might be slow depending on if my GF freaks out seeing me dismember my new machine!!!!
Take it easy and Keep Modding
Loophole
Top
#460963 - 09/05/05 09:39 AM Re:How Far Can you OC a QS 733? [Re: Medicoooo]
shadowboxer47 Offline
Send us some pics!
Top
#460964 - 09/10/05 06:51 PM Re:How Far Can you OC a QS 733? [Re: Medicoooo]
Loophole Offline
Ok So I have TRIED a few times to get a mod guide for my zip 2 HD mod but that part of the site is not working right and I dont know enough HTML to mess with it.
In any case if you want to do this here are the steps.
1) Remove the zip carrier.
2) Remove the zip drive from the carrier.
3) line up the HD on its side by the Carrier as if it was in it making sure that the IDE and power connectors line up the same way as they would if it was in the carrier (There is a slot at the back of the carrier for them).
4) mark a line where the mounting screws for the HD should be on the carrier (about 15mm either side of the rear zip mounting hole).
5) mark a across hair the same height as the middle of the existing zip mounting hole.
6) repeat steps 3-5 for the other side
7) drill at the marked crosshairs with a 1/8th or 3.0mm drill bit.
8) remove any burrs from both sides of the holes.
9) check for alignment to the HD (ie Slide the HD into the carrier all the way).
10) carefully ream out the holes in the right direction with the drill if needed.
11) repeat steps 8-10 as needed.
12) set your drive to slave (assuming your cd/dvd drive is set to master)
13) screw the drive into the carrier
14) install the carrier back into the case
15) connect up the ide and power cables.
16) start the machine and see if the drive is recognised.
You can also see the thickness of the black plastic I used in the pics I have attached.
PM me if you need some help.
Regards
Loophole
[file name=Zip2HDmodpics.zip size=425140]http://www.macmod.com/components/com_simpleboard/uploaded/files/Zip2HDmodpics.zip[/file]
Post edited by: loophole, at: 2005/09/10 18:57
Top
#460965 - 09/11/05 12:27 PM Re:How Far Can you OC a QS 733? [Re: Medicoooo]
maestro Offline
Hey, thats a great idea....but....how cool is the drive staying. Air will not circulate around it as well as it would in the bottom of the mac. Use temp monitor to check, im curious to see what its running at.
-maestro
Top
#460966 - 09/13/05 08:53 AM Re:How Far Can you OC a QS 733? [Re: Medicoooo]
Loophole Offline
Ok I dont have a temp monitor (or is it sw? if so where can i get it from?)
The drive is on the second bus (is it ATA33 or 66?) in any case I think that the carrier is dissipating a lot of the generated heat as it still feels cool (very slightly warm) after about 3 hours. This may be due to the fact that the drive is a bit older and not a high rpm model (IBM deskstar 40Gb).
in any case it runs well and I have had no lost data or any other problems.
I have also just installed a Flashed FX5200 and next will be the 800Mhz Mod.
I might need to add a larger heatsink to the FX5200 as it gets quite warm and has NO fan but I will see how it goes first.
Regards
Loophole
Top
#460967 - 09/13/05 09:16 AM Re:How Far Can you OC a QS 733? [Re: Medicoooo]
maestro Offline
Its called temperature monitor. Just Google it up and download. Its free. I always have it running. Yes, I am a tweak junky. Heres an example of my numbers. 50C cpus 29C Hd1
36 C Hd2 35C Hd3. Im still working on lowering my temps in my G4/5 case. I ordered some more Panaflos and a fan controller. Funny thing though...without temp mon. I just didnt work on stuff like that. Thats a modder for yah. Let me know your HD temp when you get the software, Im more curious now. smile
-maestro
Top
#460968 - 09/15/05 07:18 AM Re:How Far Can you OC a QS 733? [Re: Medicoooo]
Loophole Offline
Ok got Temp mon going and well after a minimum of 5 hours 'ON' the temps are as follows.
HD1 120Gb - 32 deg C (Western Digital)
HD2 80Gb - 36 deg C (seagate)
HD3 40Gb - 34 deg C (IBM Deskstar) in zip drive carrier
so it seems that the heat dissapation is not too bad IMHO (but Im no expert).
The only issue one might have is the access speed to the drive, I assume this is an ata33 bus as it was for optical/floppy access. So as long as you dont expect the world from it, it should do fine.
what do you reckon?
Loophole
Post edited by: loophole, at: 2005/09/15 07:51
Top
#460969 - 09/15/05 09:08 AM Re:How Far Can you OC a QS 733? [Re: Medicoooo]
maestro Offline
Great, those temps are within reason. Yep, its on a ata-33 bus. You can find a ata-66 pci card on eBay for cheap. Otherwise if you are satisfied with the speed, leave it. Do you have pics of the inside of your case? I would like to see it.
-maestro
Top
Page 1 of 2 1 2 >
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
Now Software Support
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.048 seconds in which 0.034 seconds were spent on a total of 14 queries. Zlib compression enabled.
