ok! i'm going to publish 2 Mod Guides, i only present in callenge the G5 Versavision in the case mod's section, and the 9600 @G4 in the case section too...
i'm looking to publish other mods... but... i'm not safe of this...
I hope this doesn't come across as too critical - but why did you choose to use wood? Further, have you though about finishing the edges of the wood with a router - maybe put a nice bevel or chamfer on the edges?
The reason because i use wood it's simple, i save the original pieces, the tft foot and the original cover. And if i need change this config to original, its so simple!
------------------------------------------------------------ but... you are right!
the edges are not very well finished
you were not first in observing it unfortunately
it thought about covering the edges... or... cover the wood with aluminum plate...
but...
I did not think about using another thing that the wood because it had that wood by hand... and I am very impatient sometimes
we could say that one is a "beta"
I have thought to finish fixing it... but... I do not think that it finishes on time for the challenge.
