An iPod with an FM Tuner? [Re: Anonymous] #460735 08/18/05 03:52 AM
J
JediJoker7169 Offline OP
Awesome
Awesome
J
Is it possible to build in an FM tuner into an iPod? Is there enough space left in there? And of course it would probably need its own software, maybe even a separate OS like iPod-Linux. But is it at all possible? Maybe you could even select stations for reception like you can for broadcast with the iTrip. Anybody seen this done?
Cheers! :-)
- JediJoker
Current:
- "ProBook:" 15.4" MacBook Pro Core 2 Duo 2.33 GHz
- Mac Classic II
- Old PowerBook
Moved On:
- "The Book of Power:" 12.1" PowerBook G4 Aluminum 1.33 GHz
- Purple iMac
Re:An iPod with an FM Tuner? [Re: Anonymous] #460736 08/18/05 09:04 AM
M
maestro Offline
M
Im gonna say no on that one. Its packed full and to get a decent tuner in there would take
up too much space. An outboard tuner is a possiblity though.
-maestro
Re:An iPod with an FM Tuner? [Re: Anonymous] #460737 08/18/05 10:43 PM
O
oojacoboo Offline
O
yea, I am with maestro on this one. That ipod is packed tight, really tight.
Re:An iPod with an FM Tuner? [Re: Anonymous] #460738 08/18/05 11:35 PM
J
Awesome
Awesome
J
So could an iTrip or other outboard broadcaster be rewired to receive? Anybody know of someone who has done that?
Cheers! :-)
- JediJoker
Current:
- Mac Classic II
- Old PowerBook
Moved On:
- Purple iMac
Re:An iPod with an FM Tuner? [Re: Anonymous] #460739 08/19/05 09:23 AM
M
maclover1986 Offline
M
Hey Joker,
I don't think an outboard broadcaster be rewired to recieve. And if could be rewired, you'd have to leave it to the pro's.
If you absolutely HAD to get an outboard broadcaster, I would strongly recommend the Belkin TuneCaster II. Unlike other broadcasters, you can set your frequency, starting at 88.1 MHz to 107.9 MHz. Plus, you can have up to four presets programmed into its memory. There is a con for the TuneCaster II: Whenever you are not using it, you have to take out the batteries, 'cause the TuneCaster will suck the batteries dry. But, if you mainly use it in the car, Belkin does provide an adapter that plugs into the cigarette lighter socket.
Trust me. I own a TuneCaster II.
MacLover1986
400 MHz iMac DV/SE, 120 GB total (with external HDs), 256 MB RAM
600 MHz iMac DV/SE, 80 GB total 384 MB RAM
2 GHz MacBook 13", 80 GB total 2 GB RAM
iPod Photo, 30 GB
iPod Video, 80 GB
iPod Nano, 2 GB
AirPort Extreme with DSL broadband
Re:An iPod with an FM Tuner? [Re: Anonymous] #460740 08/19/05 10:40 AM
M
mordaskyt Offline
M
What about building an in-line radio, similar to an in-line remote, Get the smallest radio you can find and wire it into the headphone cable, or use a male to male cable from ipod to radio and then plug haedphones into radio. Now that I think of it, there is most likely already an ipod accessory that does this...
PB G4 15" 1.2ghz - Pismo G3 400 mhz - iBook G3 500 "Jukebox"
"SawSmurf" G4 500 - Quicksilver G4 Dual 1ghz modding...
Re: Re:An iPod with an FM Tuner? [Re: Anonymous] #460741 12/17/07 06:15 AM
J
Awesome
Awesome
J
Funny... Now the iPods have radio tuners built-in. You just have to buy an antenna accessory to access it... >:D How long now before Apple becomes the Evil Empire? Is it still a rebellion? Why are STAR WARS references so prevalent in popular culture?
Cheers! :-)
- JediJoker
Current:
- Mac Classic II
- Old PowerBook
Moved On:
- Purple iMac
