• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » Mods and Hacks » Laptop Mods » Hardware Mods » ibook display
Page 1 of 2 1 2 >
Topic Options
Hop to:
#460539 - 08/09/05 03:56 AM ibook display [Re: Juinkveilibub]
zzz Offline
not to be confused with those asking whether an ibook display could be used as a second monitor, i wish to know whether an ibook g3's logic board could be rigged to have its primary output (that which is fed to the lcd display) wired to either a dvi output, or ideally in my situation to be able to take a second vga monitor...
i am under the understanding that it is a digital feed sent to the monitor, im just wondering if my allready headless ibook can run without its crummy lcd..
then i can recoup some $$$ from its now un-needed slot loading cdr/dvd, the case, and the 14' screen, and get myself a mac-mini in the process?
i am in the process of putting the ibook in its own case to 'harden' it for road use (im a musician and i actually find the ibook g3 900 with 640mb ram - i want over a gig too - adequate) im googling for adapters to get my hp lightscribe in it for dvdr support and with the added plus of burning cd graphics, and i shall be using the origingal hdd untill i can get something larger..
my intentions are to get it in a flight case/home made tough-case, ideally without the lcd
so as to reduce the size of the end mod to something more cube-like/mini-like.
oh and hi,
new to your site, looks a good resource!
zzz
smile
Top
#460540 - 08/09/05 04:53 AM Re:ibook display [Re: Juinkveilibub]
burtman Offline
If I read your post correctly you have a 14" G3 ibook 900mhz, according to
http://www.lowendmac.com/pb2/ibook14-900.html
they should have a vga output, though if its like my G4 ibook you will need a mirco-vga to normal sized vga adapter (about £15 last time I checked) assuming it boots without the main display attached you shouldn't have any problems connecting it up to another monitor (though it may only do 1024x768)
vga adater link
http://store.apple.com/Apple/WebObjects/...0.6.25.7.11.0.3
Burt
I break stuff.
Top
#460541 - 08/09/05 05:00 AM Re:ibook display [Re: Juinkveilibub]
zzz Offline
sos burt,
what i meant was i wish to use the output to the lcd from the logic board, i allready use the required adapter to obtain a vga signal, i wish to - if at all possible- get another vga/dvi port to allow me another monitor, and crucially allow me to not require a connected ibook tft display...
any ideas?
whistle
Top
#460542 - 08/09/05 05:50 AM Re:ibook display [Re: Juinkveilibub]
burtman Offline
While it might be tecnically possible, I have never heard off anybody actually taking the time and effort it would require to create/reverse engineer the interface your after.
Only thing I could suggest would be to extend the built in screen cable to the length you required, perhaps add your own connector to the side of the flight case, and the corrosponding connector to the end of your ibook screen cable and manufacture some sort of external case for the current built in scren.
You could then run screens in spanning mode using the excellent utility Screen spanning doctor to enable the feature.
http://www.rutemoeller.com/mp/ibook/ibook_e.html
This would give you dual monitor support though you would be limited to a 14" screen on once side still.
Burt
I break stuff.
Top
#460543 - 08/09/05 07:40 AM Re:ibook display [Re: Juinkveilibub]
zzz Offline
still googling like crazy on this:
as stated in your low end mac link:
Video: ATI Mobility Radeon 7500 with 2x AGP
VRAM: 32 MB
displays: 14.1" 24-bit SVGA (1024 x 768) color active matrix, resolution scaling for 640 x 480 and 800 x 600 modes
video out: VGA and composite video
now i know that the vram on the mac is shared accross the two monitors, regardless of their size + type, this isnt a problem.
whats interesting tho is that the logic board feeds svga..
more googling so far has taken me to this link:
http://www.interfacebus.com/Design_SVGA_PinOuts.html
(svga pinouts)
The table above provides the pinouts and signal names for the connectors. A 15-pin SVGA cable has the same pinout as a 15-pin VGA cable; however, VGA may also be found with a 9-pin D connector.
reading up also on the ati website on their 7500 mobility card which i also must point out is a very popular laptop graphics solution..
now im going to try and find a broken lcd display suitable for my job (i wish to remove the connectors to try and create a custom vga/svga port - thus allowing me to flog me 14' lcd) any one offering me their old defunt lcd for the good of the headless ibook cause?
B)
Top
#460544 - 08/09/05 08:24 AM Re:ibook display [Re: Juinkveilibub]
zzz Offline
http://www.ati.com/products/embedded/mobilityradeon750032/features.html
ati radeon mobility 7500 features,
seems it supports dual display in various formats, notably with the ibook its one 24-bit SVGA to the tft, judging by further googling there should be no problems connecting a vga monitor to a svga port, as this is the norm and is often done..
just need the pinouts now from the area where the lcd connects i imagine.
if at all possible could anyone in the uk send old lcd monitor connection cables that will connect to my logic board in the manner my lcd does - butcher them off the faulty lcd - theres a pint in it if u do!!
- this means i can build a custom lead + share any findings back with the community
smile
Top
#460545 - 08/09/05 08:30 AM Re:ibook display [Re: Juinkveilibub]
zzz Offline
hmm back to the drawing board for a while:
http://developer.apple.com/documentation..._section_3.html
seems it has xga, need to be 100% sure what signal is fed to the lcd.
*goes a googlin'*
Top
#460546 - 08/09/05 08:34 AM Re:ibook display [Re: Juinkveilibub]
krusher117 Offline
have you checked to make sure that your ibook support dual monitors? Some of them only support mirroring which wouldn't be useful for what you are trying to do.
Top
#460547 - 08/09/05 08:36 AM Re:ibook display [Re: Juinkveilibub]
burtman Offline
Signal going to the LCD is most likly going to be LVDS, or some version of that 'standard', but you would then need to convert that to vga. Not an easy task I imagine.
Burt
I break stuff.
Top
#460548 - 08/09/05 09:16 AM Re:ibook display [Re: Juinkveilibub]
zzz Offline
looks like i have a solution for a cheap airport, while googlin for pinouts, lol...
http://www.macfixitforums.com/php/showfl...o=31&fpart=
still no more info on the logic board in question
Top
Page 1 of 2 1 2 >
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
Now Software Support
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.060 seconds in which 0.044 seconds were spent on a total of 14 queries. Zlib compression enabled.
