• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » Mods and Hacks » Desktop Mods » Case Mods » Headless iMac Mods
Page 1 of 3 1 2 3 >
Topic Options
Hop to:
#460495 - 08/07/05 04:51 PM Headless iMac Mods [Re: LymnCyncEcomb]
Draconis Offline
I have an 800Mhz flat panel imac that i am going to make into a headless server.I was wondering if there is anything cool i could do to the case or any mods to make it run faster. I looked around Mac Mod but flat panel imac mods don't seem to be too popular.
Draconis
"A wise man speaks because he has something to say. A fool speaks because he has to say something."
"I do not condone, nor suggest the use of PCs."- Maestro
Top
#460496 - 08/07/05 08:28 PM Re:Headless iMac Mods [Re: LymnCyncEcomb]
oojacoboo Offline
well, its a fairly new machine and not very easily modable. Although, you could always house it in a new case or you could pain the case like this one...
http://www.macmod.com/content/view/19/2/
But, I think that it would look cool just by itself, headless. Maybe you can put a lighting effect under it like the powermate.
Mac Pro Quad 2.66 - 4GB RAM
Quad 19" Widescreen LCDs
Accessorized to the Hilt
Top
#460497 - 08/07/05 08:44 PM Re:Headless iMac Mods [Re: LymnCyncEcomb]
Draconis Offline
Well in the few hours before your post i thought up some pretty cool ideas.
1. Move power button to where the arm currently is.
2. Since i'm taking out the CD drive for a second HDD the CD cover(oblong piece of plastic that flips down when the CD comes out) will have 3 indicator lights. One for each HDD and another one to show its hooked up to the network.
I like your idea about the powermate. I was thinking maybe EL wire in between the logic board and plastic air vents or is that not bright enough?
Also I thought of a name. The Mac Orb. Is that too cheezy?
Draconis
Top
#460498 - 08/07/05 09:48 PM Re:Headless iMac Mods [Re: LymnCyncEcomb]
oojacoboo Offline
sounds bad ass to me wink
Love the idea with the power button and the drive and netowork activity led indicators. As for the powermate look, I was thinking something like a strip of plexiglass molded around the base so that it is just about an inch high, then mount lights under there. You could sand the plexiglass as well so that it has a hazy look. I duno if plexiglass is exactly the right material, but, you get the idea.
Top
#460499 - 08/07/05 10:06 PM Re:Headless iMac Mods [Re: LymnCyncEcomb]
maestro Offline
That does sound phat. Is the lcd broken? You can overclock those imacs too. Maybe some
slight cooling mods would be in order though.
-maestro
Top
#460500 - 08/07/05 10:30 PM Re:Headless iMac Mods [Re: LymnCyncEcomb]
Draconis Offline
There is a problem with the LCD but, its not worth it to fix the problem. If it ever needs a display the external connecion still works fine and I'm going to put VNC on it. I looked into overclocking. the only problem would be extra cooling while still being virtually silent as this imac would run 24/7.
Post edited by: Draconis, at: 2005/08/08 00:06
Top
#460501 - 08/08/05 02:54 PM Re:Headless iMac Mods [Re: LymnCyncEcomb]
Draconis Offline
Sorry i skipped your post oojacoboo. I was kinda tired last night .The only problem i see with that is how to light it all around without lights on the outside. If i cut out a hole in the center of the plexi and put in EL wire or LED's would that work?
Post edited by: Draconis, at: 2005/08/08 14:56
Top
#460502 - 08/08/05 03:25 PM Re:Headless iMac Mods [Re: LymnCyncEcomb]
oojacoboo Offline
actually yea, that might work best, to cut a hole in the plexiglass, using the thickest plexiglass you can find, and then cut the outside as well in a circle just a little larger. Maybe you could even do two of these and glue them together to make it even thicker. Then just take the light strip and go all the way around underneath the imac on the inside of the circular strips. Add a little sandpaper to the plexiglass to scuff it up a tad and then you should have something that looks alot like a powermate. Giving you the orb effect wink
The point it to raise the base of the imac off the ground just a little, with a hollow middle for the lighting.
Post edited by: oojacoboo, at: 2005/08/08 15:27
Top
#460503 - 08/08/05 05:19 PM Re:Headless iMac Mods [Re: LymnCyncEcomb]
Draconis Offline
Ok, i'll do that. Where would be a place to buy a pwrbook or G5 tower pwr button? I know of ebay i was just wondering if there was another place.
Top
#460504 - 08/08/05 05:30 PM Re:Headless iMac Mods [Re: LymnCyncEcomb]
oojacoboo Offline
actually you might give some apple repair shops a call. They might be able to hook you up. I would give techrestore a call and tell them you are working on a mod for the mod challenge, if indeed you are, and they might be able to help.
Top
Page 1 of 3 1 2 3 >
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
Now Software Support
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.059 seconds in which 0.041 seconds were spent on a total of 14 queries. Zlib compression enabled.
