• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » Mods and Hacks » Desktop Mods
      » Hardware Mods » Slot-Load DVD in Tray-Load iMac
Page 2 of 3 < 1 2 3 >
Topic Options
Hop to:
#460335 - 07/28/05 09:09 AM Re:Slot-Load DVD in Tray-Load iMac [Re: Anonymous]
TCPMeta Offline
MacModder
Ok, I have found out some things. I was wrong about the tray-load CD-ROM IDE was part of the hard drive IDE connections. They're diffrent. Also I found out my hard drive I had in it had a bad sector so I replaced it with the 40GB drive I had in the other iMac.
I took out the tray-load and DVD and placed in the slot-load 24x CD-ROM. I got it to boot from CD.The CD-ROM is set to master and the harddrive is set on cable-select For some reason my MacOS 9 CD isn't bootable. I think it's because of a massive scrach on it. Right now i'm using my iMac system restore CD to put Mac OS 8.6 on then i'll install Mac OS 9 over it.
After I finaly get Mac OS 9 installed I will put the DVD back on and test it. I think the DVD Drive might be bad. If it is and since it will be external I will try out my internal Iomega ZIP-CD 650 drive that from I was told is Apple compatable. It can play DVDs aswell. I have started on the fabrcation for a small case to hold the AT power supply and the drives im going to use. Maybe in the furture i'll do the iMac ATX case mod or even build my own small like case like I have done in the past with a ITX system.
I'm going to do as much modding to this iMac as I can. I've been looking at the Floppy drive mod. Not sure if my iMac can hold one or not. If not then i';; just get a USB Floppy or something.
I ordered two sticks of 128MBs for the iMac. I heard a rumor that it can hold infact 384MBs of ram, at the time there was only 128MB simms out when the iMac came out. Never know. Anyway i've seen a few CPU upgrades for this iMac also so when the prices go down i'll order one.
To live is to let die
Top
#460336 - 07/28/05 10:08 AM Re:Slot-Load DVD in Tray-Load iMac [Re: Anonymous]
krusher117 Offline
http://store.fastmac.com/product_info.php?products_id=99
Can you do something like that? They also have a $149 slot load combo drive if you didn't need the burning capability.
Top
#460337 - 07/28/05 01:48 PM Re:Slot-Load DVD in Tray-Load iMac [Re: Anonymous]
whitlock Offline
Moderator Emeritus
Your machine can hold a lot more than you think. I've stuck the max ammount in a customers machine and it flew. It's worth maxing it out.
iMac Maximum RAM Guide:
Original G3 iMacs = 512mb
iMac DV's & SE's = 1gb
Flatpanel G4iMac = 1gb
G4 1ghz+ Flatpanel iMac = 2gb
G5 iMac = 2gb
/Figured I would stick this here if anyone needed a reference guide for later, especially people who search the forums for info
Canon Rebel XTI
Google Cr-48 Beta Laptop
Top
#460338 - 07/28/05 01:53 PM Re:Slot-Load DVD in Tray-Load iMac [Re: Anonymous]
maestro Offline
I think you should stop and take a breath for a second. Is this computer worth all the potetnial
expense. I dont want to be the one saying dont mod it, but make sure you take cost/use/time
into consideration. Do you need an all in one? What do you want to do with it? What is it
actuallly capable of? You never know, you may decide that you need a dfiferent starting point.
Ive had some macs fall into my lap before and came up with some great ideas. BUT, after much
thought it just wasnt worth it. I still have one of them, but each day it becomes less and less
useful. Just some thoughts.
-maestro
Top
#460339 - 07/28/05 02:06 PM Re:Slot-Load DVD in Tray-Load iMac [Re: Anonymous]
TCPMeta Offline
MacModder
I'm modding this because im a modder, I mod anything I can get a hold of lol. Thing is I can always turn this iMac into a tower/desktop based system instead of a all-in-one. I've only spent in all 50 bucks on this project. All of the other parts i've had from other systems have been eather tossed out or given to me. If I can give this more ram and a faster CPU then I don;t need to go out and spend a arm and a leg for a brandnew mac that I will end up ingoreing after some time.
After I complete this mod and share to you all the guide im making for it I will probly gut the other iMac and build a iPC or something.
I would buy another Apple but people want way too much for a classed out system. If it's under 500MHz it's not worth 100 bucks. Ofcorse this is comming from someone that deals with PCs then with Macs.
Top
#460340 - 07/28/05 03:55 PM Re:Slot-Load DVD in Tray-Load iMac [Re: Anonymous]
TCPMeta Offline
MacModder
Heres a quick draft I made for the guide. The pictures are curde but gives better detail at the moment. I found a way to make it internal but havn't tryed it yet.
[url=FTP://mod@68.209.133.69:21]FTP://mod@68.209.133.69:21[/url]
If it asks for a password leave it blank.
Top
#460341 - 07/28/05 10:46 PM Re:Slot-Load DVD in Tray-Load iMac [Re: Anonymous]
oojacoboo Offline
it timed out.
Mac Pro Quad 2.66 - 4GB RAM
Quad 19" Widescreen LCDs
Accessorized to the Hilt
Top
#460342 - 07/29/05 12:43 PM Re:Slot-Load DVD in Tray-Load iMac [Re: Anonymous]
TCPMeta Offline
MacModder
Yea, sorry about that. I turned off my server lastnight due to it heating up my office. my A/C went out again. but it's all sorted out again.
Top
#460343 - 07/29/05 12:48 PM Re:Slot-Load DVD in Tray-Load iMac [Re: Anonymous]
oojacoboo Offline
.bmp? hmmmm..... :huh:
Top
#460344 - 07/29/05 12:59 PM Re:Slot-Load DVD in Tray-Load iMac [Re: Anonymous]
TCPMeta Offline
MacModder
Yea, I used my PC and didn't feel like playing with gimp or paintshop. Like I said it's only a short draft. When I re do it i'll convert the pictures to PNG or something.
Top
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
Now Software Support
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.050 seconds in which 0.031 seconds were spent on a total of 14 queries. Zlib compression enabled.
