• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » Mods and Hacks » Laptop Mods
      » Case Mods » Help! Kyboard/Apple Light Typewriter Mod!
Page 1 of 2 1 2 >
Topic Options
Hop to:
#460155 - 07/14/05 01:45 PM Help! Kyboard/Apple Light Typewriter Mod! [Re: shail_gupta]
Seaniccus Offline
(Reposting because I posted it in the Desktop forum by mistake.)
Howdy! I'm new to not only Mac, but Mac modding - And I'd like some vetran help with a prospective project before I start pouring money into it.
My plan is to make a typewriter case mod for a 12" Powerbook. This project is a collaboration of two major modifications:
1.A keyboard mod in which all of the standard keys are replaced with old (1940's black, round with silver edges style) typewriter keys.
And
2.Replacing the "Apple Light" on the back with a "Typewriter light," in the shape of an old-style typewriter.
Not knowing much about the hardware or modding community, I wouldent know where to start. THe main information I'd like to know is as follows:
Where woud I buy a replacement "back" for the screen, wherre the apple light is? (So I can build the new one.)
Where can I find a replacement keyboard, so I can keep the origional parts if I want to convert it back?
Is it difficult to replace the keybaord, and do you think it's possible to replace the key's without putting the monitor at risk?
Thankms for your help guys. I just haven't been able to find these answers on my own.
Top
#460156 - 07/14/05 01:58 PM Re: Help! Kyboard/Apple Light Typewriter Mod! [Re: shail_gupta]
whitlock Offline
Moderator Emeritus
*duplicate taken care of*
Where woud I buy a replacement \\"back\\" for the screen, wherre the apple light is?
Either an Apple Authorized Repair Location or on a site like eBay.
The keyboard is fairly easy to remove. That is not a concern. What is a concern is the keys being to tall. If you don't shave down the keys fine enough, you'll end up having the keys dig into the display. That would not be good. Now, with typewriter keys, some may be usable. Start hunting for old typewriters with keys you can file down.
Canon Rebel XTI
Google Cr-48 Beta Laptop
Top
#460157 - 07/14/05 02:00 PM Re: Help! Kyboard/Apple Light Typewriter Mod! [Re: shail_gupta]
krusher117 Offline
Are these the kind of keys you are talking about?
Also, can you be more specific about what the "typewriter light" is?
Top
#460158 - 07/14/05 02:02 PM Re: Help! Kyboard/Apple Light Typewriter Mod! [Re: shail_gupta]
krusher117 Offline
I was going to say the same thing whitlock. Seaniccus i think this is doable with very thin keys. It will be difficult, but possible, to glue the "scissor hinge" to the back of them too. This mod will be amazing if you can pull it off. There's nothing impossible about it tho.
Top
#460159 - 07/14/05 02:36 PM Re: Help! Kyboard/Apple Light Typewriter Mod! [Re: shail_gupta]
Seaniccus Offline
Yes, those are the kind of kyes i'm talking about.
OKay, so you know how on the back o fthe monitor (The top of the powerbook, when it is closed) is the "Apple Logo?" YAnd you know how it lights up when the powerbook is on, right? I want it to replace it with a "Typewriter logo" that would look something like this, but much more customized, and more of a "Lighted Outline"
This whol project was sort of inspired by the comic book TRANSMETROPOLITAN, the stroy about a rouge journalist in the future, who's "Typewriter" is a high-tech laptop with typewriter keys.
Thanks guys, any more suggestions?
(Yeah, and it looks like affiixing the keys is going to be a pain in the ass. it also looks lik ei'll have to make a fair share of custom keys. This is going to be a bitch.
Top
#460160 - 07/14/05 03:57 PM Re: Help! Kyboard/Apple Light Typewriter Mod! [Re: shail_gupta]
oojacoboo Offline
I don't think this is going to be as hard as you think. You could pull of the keys, shave the backs of them down flat, then glue on the bracket to the back and it should work fine. Making sure you shave them down ehough would obviously be the main issue. Yes, you would have to make custom keys or you would have to just live with the stock ones for all the rest.
As for the logo. You may be able to get a new cover and then cut out a larger typewriter icon over the apple one just so the outer shape of the typewriter is the shape you cut out. Then, take a black and white image of the typewriter the same size and paste it underneath that so it shows all the details. Keep in mind that you will need some cloudy arcrylic to replace the apple one. Not too sure how you are gonna find that one. Prob have to make it custom. I dont' know much about custom arcrylic work and/or making it cloudy. Maybe someone else can help there.
Mac Pro Quad 2.66 - 4GB RAM
Quad 19" Widescreen LCDs
Accessorized to the Hilt
Top
#460161 - 07/14/05 04:48 PM Re: Help! Kyboard/Apple Light Typewriter Mod! [Re: shail_gupta]
whitlock Offline
Moderator Emeritus
At some hobby stores, you can pick up an acrylic molding kit for ~$30 or so. You can mold the Apple in there and pour a new one with the logo inside, or cut a circle into the back of the display housing and then mold a circular with the logo in there as well.
It's a lot easier than cutting, though a saw and file will do as well. You can pick up a piece of acrylic, maybe even already in the size you want, and just cut it out. After it's in shape, you may need to sand the edges and buff them so they don't have an unfinished look.
Oh, the options!
Canon Rebel XTI
Top
#460162 - 07/14/05 04:49 PM Re: Help! Kyboard/Apple Light Typewriter Mod! [Re: shail_gupta]
Waragainstsleep Offline
Are you going to make the keys click like a typewriter? Maybe a software hack when you finish modding the keyboard....?
Top
#460163 - 07/15/05 12:03 AM Re: Help! Kyboard/Apple Light Typewriter Mod! [Re: shail_gupta]
Seaniccus Offline
Yeah, that's a seperate project - skins and custom sounds for the OS.
My biggest issue right now I think is buliding custom keys for things like alt, the apple bototn, backspace, arrows, etc. I'd like the whole thing to look generally uniform. I havne't thought of much of an approch for the light up logo yet, because I havent seen what I have to work with - My biggest concern is the size of the light i'm working with - how far spread out it can be.
I'm bid on a keyboard on ebay to get started on the keyboard with. I might have most of the parts ready before I actually buy the Powerbook. I'll post pictures as I go along.
Top
#460164 - 07/15/05 01:20 PM Re: Help! Kyboard/Apple Light Typewriter Mod! [Re: shail_gupta]
whitlock Offline
Moderator Emeritus
Glad to hear that you are going through with the project. Keep us updated, and don't forget to make a mod guide once everything is complete.
Canon Rebel XTI
Top
Page 1 of 2 1 2 >
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
Now Software Support
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.044 seconds in which 0.032 seconds were spent on a total of 14 queries. Zlib compression enabled.
