i have a 1ghz 15 powerbook. I edit wedding videos for work and am already using a 19in crt. but it would be nice to be able to connect my 14in tv as well.
is there a hack similar to the ibook/imac (which ever it was) hack, that would let me use the s-video as well as the dvi for 3 total monitors....?
macDeviant
Post edited by: macdeviant, at: 2005/07/05 18:21
Don't know of such a hack I'm afraid. There is a way you can have a third monitor, its called the VTBook from villagetronic. It'll run DVI if you want. Those puppies aint cheap though....
