This question is mainly for those that have painted B&W G3 cases. I am in the process of painting my B&W case, and I need to know how to paint that little rubber grommit that goes on the sidepanel latch. I'm looking to paint it red. The color scheme is Red @ Silver and it looks pretty good so far. thanks -jeff
Hmm, something that don;t chip or make the rubber brittle. I would say hair color but that might make the rubber brittle. How about a marker then coat the rubber with beeswax or a thin layer of glue. Ofcorse this will turn the rubber into something hard but it will color it.
When I painted my B&W G3, I tossed the rubber piece in a junk bin. It didn't help me out any, but I did find it on my desk just now.
If you get crunched on your mod for the challenge and you want the rubber piece due to a mishap, just PM me through the site and I'll throw it in the mail.
