i was just wondering, since i found a site that sell g3 laptops for cheapness and also G4 logic boards, will a G4 board fit in a G3 and have all the same connectors? i googled all sorts of stuff related to this and could find no answer.
15.4 in matte Macbook Pro, 2.4 Ghz, 2 gb, 200 gb, 256mb 8600m GT. 2 Ghz Celeron, 2 gb, 40 gb, 128mb fx5200, ubuntu based file and print server.
yeah i was wondering because it would be cheaper to buy a G3 and keep the hard drive and optical drive and case but just switch out the old board for a new one, then sell the old one.
Loc: Vancouver, BC Canada
far too much fuss to save a few bucks and you could easily end up in the hole.
actually it can't be done #1 the frames are different sizes and #2 the connectors to everything are different.i know this because i wanted to do the same thing and found i i could not also i have been inside the i book and if you have never opened one up the risk is not worth it i would say sell your old one save up about 300-400 more dollars and buy the 12 inch g4 for 999 through apples website.
i just remembered this, im pretty sure that once on ebay there was an ibook that was a G3 case modded to be clear with a G4 mobo in it. maybe the guy was lying, i dunno, but he was selling a G4 in a g3 case.
