iPod and WMA?? [Re: brianresler] #459312 04/21/05 11:31 AM
T
thavok Offline OP
T
Ok so I was talking to one of my friends who said that iPods would soon be supporting wma. So I looked all over google and couldn't seem to find any reputable sources just a lot of rumors can anyone confirm this or is this just a rumor.
Re:iPod and WMA?? [Re: brianresler] #459313 04/21/05 12:48 PM
K
krusher117 Offline
K
maybe they are confused by the fact that the iPod supports WMA. This support is turned off by Apple, but its there. Will Apple release and ipod update that activates this support? Its very likely. Will it happen anytime soon. Its VERY UNLIKELY (as long as they have above 30% market share).
Re:iPod and WMA?? [Re: brianresler] #459314 04/21/05 02:16 PM
U
ubergeek89 Offline
U
Umm I'm sorry to say but who accually uses WMA?. Smaller file sized compromizes audio quality unless your used to low quality audio devices.even AAC has its downsides (though it is the best compressed format by far). This is a little off topic, but listen to a high quality professionally recorded standard audio cd on a stndard stero cd deck with an 80's analog amp and equilizer and there is simply no comparison. Digital formats are good simply for their portability. (i'm not going to be carring around my yamaha natural sound receiver from 1979 and my sound shaper 24 from 1984 and a cd deck though it would be a helluva mod). But my point is WMA has no comparison to cd quality no matter how high the bitrate is. Lately I've ripped my cd's at 192kbps AAC and they sound ok.
-Jeff
Mobile-2.2Ghtz Core 2 Macbook, 4GB ram, 160GB HDD
Server-Dual 1.42 MDD G4, 1GB ram, 4 random hard drives.
PC-C2D 2.4Ghtz, Asus Commando, 2Gb ram, 3 hdd's in raid 5, 8800GTS.
Re:iPod and WMA?? [Re: brianresler] #459315 04/21/05 03:13 PM
T
thavok Offline OP
T
thanks for the insight but I am mostly asking because I have a friend who's entire libary is WMA. Mine of Course in completely AAC and has been for a while. ever since iTunes for Windows.
Re:iPod and WMA?? [Re: brianresler] #459316 04/21/05 06:21 PM
W
whitlock Offline
Moderator Emeritus
Moderator Emeritus
W
AAC for one, WMA for the other. I would have, like I did, stuck with MP3 since it will work on any device.
Canon Rebel XTI
Google Cr-48 Beta Laptop
