I have a set of USB Apple pro speakers (manufactured by klipsch i beleive) and I want to use them on a pc. My PC sees them as a USB Audio Device, but they don't work. Just curious if anybody has a weay of making it work. Thanks for the help -Jeff
well wut i would do is take a cord that fits the headphone jack and plug that in to the computer and that should work or find how to configure ur settings by installing the speakers... u shoulod be able to righ click i believe and install them but im not sure. i will try to find out and get back to u but meanwhile i wold try that headphone jack. i had speakers i did that they work jsut fine.
The speakers you speak of, pun intended, run both power and audio (digital) though the usb port. The speakers then take the audio and convert it to analog and then amplify it to the speakers. With that in mind, you need to convince the computer to send the audio to the speakers. You need a driver for that. Thats the thing about PCs that I do not like. I like the plug and play Mac. It can work. Look for a driver. You may want to consider posting on a PC site too. They would probably know more about it. -maestro
Sorry, those speakers can only be used on a Cube. In fact, they were made to only work with the Cube and nothing else. They require higher power than conventional USB can provide. So even if you got the power to them, you would need to make sure the USB Audio driver could work with it.
Ooh, thats not good. But dont lose hope. Anything is possible. Like I said, find a driver. Look into what whitlock said (get the specs. on usb voltages). It is still worth a try. -maestro
You are correct about the power. here is an article I found about apple branded speakers, and they are made by harmon/kardon, not klipsch (similar companies though). The problem is apple computers have 10 watt usb ports, but normal usb ports are only 2.5 watts. Oh well. the article can be found here: http://www.lowendmac.com/tf/010531.html
I believe you can get this to work for a price that is totally unreasonable.
Before you try it tho, try plugging the speakers into a powered USB hub. If your computer is picking them up as USB speakers then there is a chance they will work with the right amount of power.
