• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » Mods and Hacks » Desktop Mods » Misc. Mods » G5 Cathode Help
Page 1 of 2 1 2 >
Topic Options
Hop to:
#458325 - 02/25/05 11:39 PM G5 Cathode Help [Re: befriton]
oojacoboo Offline
This thread is being submitted on behalf of "Ice91"
Hey guys I'm just getting into moding my dual 1.8ghz G5 and would like to add some lighting to it. Problem is I don't have any clue how to do it. I've seen that many people have used cold cathode lights and I see they are powered by the standard power supply plug but I can't seem to find the right plug on my G5. Maybe it's because I'm a little hesitant to start ripping it apart without really knowing what I'm doing. So if any of you would like to give me some pointers on how to set up a cool lighting set up I would greatly appreciate it. Any and all tips are welcome.
Post edited by: oojacoboo, at: 2005/02/25 23:39
Mac Pro Quad 2.66 - 4GB RAM
Quad 19" Widescreen LCDs
Accessorized to the Hilt
Top
#458326 - 02/26/05 12:11 AM Re:G5 Cathode Help [Re: befriton]
oojacoboo Offline
Jack, the first thing that I can tell you is that you can't be too scared to get started. However, have a little fear is never a bad thing when you are messing with an expensive piece of equipment. wink Having done this mod just a few weeks ago myself, I can tell you that it was a piece of cake.
First you will want to start out with a pair of cathodes. Gearbox has some great stuff for excelent prices. I would choose the 12" Cathodes.
http://stores.ebay.com/computer-parts-wholesale-lots
They sell the pair that has everything you need to complete the mod. It comes with:
[ul]
(2) 12" Cold Cathodes
PCI switch to turn the lights on and off
Inverter that can control both cold cathode lights
Mounting Tape, Velcro Tape, Screw included [/ul]
Personally, if I were doing this mod again I would get a set of smaller cathodes as well. It is very difficult to get the cathodes to emit light through all of the sections of the G5. I had to do some dremel work on my system to get a 12" cathode in the top. I had never seen anyone do it that way and I felt that it was a much needed addition. The G5, as a result, looks alot more equalized.
You can have a look at this thread where I submitted some images.
http://macmod.com/component/option,com_simpleboard/Itemid,/func,view/catid,23/id,3077/#3077
Now, you had questions on how to locate the plug. What you are going to need to do is borrow the one from the optical drive. The kit that I recommended comes with the converter. Therefore, all you have to do is remove the optical drive from it's bay. Unplug the power cable and run the splitter. From there you will just run the included wiring to the cathodes and place there where you like. There is a pci switch that you can add to the back of your system so that you can turn the cathodes on and off as well.
The hardest part about this mod is the placement of the cathodes. I am also very meticulous so I spent alot of time concealing the wires. I wrapped them all in electrical tape.
You can see here where I placed the inverter box. It is located on the back of the internal speaker.
Here are some additional picture of where I placed the cathodes in the system. In this first one you can see where I had to dremel out a notch so that the cathode could fit. There is no other way because the cathode is too long. I know that it is not the most attractive cut, but the only way to get that is to take out that fan, and that would require a disassemby of nearly the entire G5. I wasn't about to do that :side:
This next image is a picture of the one that I placed in the front of the G5. What you can not see in this image is the electrical tape that I placed on the revese side, the side that faces the front of the case, you. I know, you are probably asking, why would you do that. Well, all too often these cathodes mods come out and the only thing you can see is the cathode, not the light from the cathode (I know you see the light). I wanted to block the direct light so that it wasn't overbearing. The result, is a pleasing illumination of the case and not a shining light.
On this cathode that is placed in the front, you will have to slide it down the tightly fitting front, between the cheese grated metal and the support for the bottom section. After you have decided your positioning, just place the velcro on the cathodes and put them into place. Keep in mind that once you stick the velcro to the computer its going to stay there. So, don't make any mistakes.
Finally, have fun and be creative, take plenty of pics and enjoy. Let me know if you have any other questions.
Cheers,
Jacob
Top
#458327 - 02/26/05 12:25 AM Re:G5 Cathode Help [Re: befriton]
Ice91 Offline
Thanks for the help.
Top
#458328 - 02/26/05 12:29 AM Re:G5 Cathode Help [Re: befriton]
oojacoboo Offline
you bet, I want to see the progress. You are going to go ahead with it, right?
Top
#458329 - 02/26/05 12:32 AM Re:G5 Cathode Help [Re: befriton]
Ice91 Offline
Here's the pics
Post edited by: ice91, at: 2005/02/26 00:36
Top
#458330 - 02/26/05 12:42 AM Re:G5 Cathode Help [Re: befriton]
Ice91 Offline
oops here are the real pics
Post edited by: ice91, at: 2005/02/26 00:43
Top
#458331 - 02/26/05 12:44 AM Re:G5 Cathode Help [Re: befriton]
Ice91 Offline
Top
#458332 - 02/26/05 12:45 AM Re:G5 Cathode Help [Re: befriton]
Ice91 Offline
Post edited by: ice91, at: 2005/02/26 00:46
Top
#458333 - 02/26/05 12:49 AM Re:G5 Cathode Help [Re: befriton]
oojacoboo Offline
already did the mod that fast? You already had everything and were ready to go and just couldn't find where to plug it up? Try some electrical tape on the front of those cathodes to diffuse some of that direct light, that way you can't see the cathodes.
Glad to see that you have 4 cathodes, it really takes that many to illuminate the whole case.
Top
#458334 - 02/26/05 12:52 AM Re:G5 Cathode Help [Re: befriton]
Ice91 Offline
Yeah I'm fast when it comes to these kind of things. I guess that comes from being a theatre lighting tech...you have to work fast and make your work look good.
Top
Page 1 of 2 1 2 >
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
Now Software Support
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
View homepage
Add to your Watched Users
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.056 seconds in which 0.037 seconds were spent on a total of 14 queries. Zlib compression enabled.
