The Apple Pro mouse begs to be taken apart for modding. It is super easy. Take a razor and the eight main epoxy points. Run the razor between the white and clear section and you will find them. Youll will know when they are all broken and it will seperate. That is all it takes to get the clear case off. The white part is solid white plastic. No need for an alcohol bath here. B) Now you can tape the cord and bottom and its ready for paint. You could even put a decal on it for easier mod. I will put up a mod guide eventually (its way to cold in Wisconsin to be spray painting. I may find something else for it too. Oh yah, I forgot, you wil need to epoxy it back together. -maestro
