In the 1st generation eMac, the logic board has TWO blind-mate connectors that go directly to the analog module assembly, whereas the 2nd and 3rd gen eMacs have only one.
I don't know if the second connector is of any use (if it is there, it must do something ), or if I can try power up the eMac directly through the main connector (the one which is common in all generations - top left in the photo) using an "hypothetical" ATX conversion with the voltage info available in this thread.
If someone has access to a 1st gen eMac, it would be of great help if he could measure all pin voltages in both blind-mate connectors.
Thanks
Post edited by: netjosh_granada, at: 2005/01/25 19:36
