• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » Mods and Hacks » Desktop Mods » video card flashing.
Page 1 of 2 1 2 >
Topic Options
Hop to:
#457478 - 01/08/05 08:54 AM video card flashing. [Re: egoggle]
chrisrice Offline
i wondering if it is posible on a mac to flash a video card to a higher version. or flash a pc video card with mac bios and make it run in a mac.
are there 3rd party drivers for video cards.
Top
#457479 - 01/08/05 09:21 AM Re:video card flashing. [Re: egoggle]
oojacoboo Offline
I do believe that it is possible. I have never had the desire to do it myself, but, here are some links that you may find useful...
http://macmod.com/component/option,com_simpleboard/Itemid,/func,view/catid,23/id,2439/#2439
http://www.xlr8yourmac.com/G4ZONE/G4firmwareMXrom.html#storytop
http://www.macosxhints.com/article.php?story=20020712084851928
Series of Flashing Instructions:
Radeon 7000 - 9100 AGP
Radeon 9200
Radeon 9800
Geforce 2, 3, and FX
:unsure:
Good luck. Would love to see a mod guide made for this and posted on macmod.
Post edited by: oojacoboo, at: 2005/01/08 09:22
Mac Pro Quad 2.66 - 4GB RAM
Quad 19" Widescreen LCDs
Accessorized to the Hilt
Top
#457480 - 01/08/05 10:51 AM Re:video card flashing. [Re: egoggle]
chrisrice Offline
see i'm what you call code illeterait. i need someone to show me step by step.
what i need is a video card that has an dvi and apples little monitor type (the name escapes me now) cuz i got one of thoes new 23inc monitors and my gforce 4 ti is close to not cutting it anymore.
is it posible to put an ultra on it.
Top
#457481 - 01/08/05 12:29 PM Re:video card flashing. [Re: egoggle]
oojacoboo Offline
you are talking about ADC. The latter links listed above are step by step instructions for flashing your video card.
What computer do you have, and what are the specs? You are just trying to get a video card with DVI and ADC onto your current system so that you can use a 23" Apple Display, correct?
Top
#457482 - 01/08/05 01:25 PM Re:video card flashing. [Re: egoggle]
chrisrice Offline
everone seems to get confused when i say this. the new monitors use a dvi port, and the old one's have a adc port. thoes are what i have. yes i am looking for a video card that has thoes ports so i can run my 2 monitors better.
i am using a dual g4 1.25 (not modified), with 2gb ddr sdram pc2600 ram, a nvidia gforce 4 ti 4600.
the reason i am looking towards flashing is that the card i have is almost the best one i can get for a g4 with the ports i need. (or at least i think)
this was just an option i was exploring.
Post edited by: chrisrice, at: 2005/01/08 13:29
Top
#457483 - 01/08/05 02:23 PM Re:video card flashing. [Re: egoggle]
oojacoboo Offline
I use to have that exact system, great computer... wink
I am currently running 2 DVI monitors that are 1600x1200 a pop. I am running the ATI Radeon 9600 (I am pretty sure). It has one ADC port and one DVI port. The DVI port in the back of the system is DVI-I (meaning that it carries both an analog and digital signal). The new Apple displays should be DVI-D displays, therefore it is possible that they will work with any ADC to DVI converter. However, I experienced problems with all of the converters except for the DVI Extractor II by Dr. Bott.
http://drbott.com/prod/db.lasso?code=0123-ADE2
So, if I am not mistaken the Video card that is in your computer has one ADC and one DVI port, correct? If this is the case, you should be able to just purchase the DVI Extractor II, run that from the ADC port to one of the LCDs. Then, just run the other one directly to the DVI port in the back of your video card as it is.
I hope this helps. Did I understand you correctly? :huh:
Top
#457484 - 01/08/05 10:27 PM Re:video card flashing. [Re: egoggle]
maestro Offline
Okay, the g4ti is a pretty good card. I would either overclock it or buy a 9800.I dont think you can flash that one with a higher version. But with some ram heatsinks and a larger gpu heatsink, you could overclock for better performance. Are you a gamer, if not I wouldn't bother getting a new card.
-Maestro
Top
#457485 - 01/09/05 04:01 AM Re:video card flashing. [Re: egoggle]
chrisrice Offline
yea i'm a gamer.
Top
#457486 - 01/09/05 09:22 PM Re:video card flashing. [Re: egoggle]
maestro Offline
If you are a gamer, you need to stay on top of the video changes. Go with a 9800 pro and over clock to an xt. With ATIccelator II and some heatsinks as I said before will let you do that. The nice thing is that the price just dropped to 250 bucks. Buy the mac one and you won't need to bother with flashing because it doesn't save that much money anymore. Get it and you will be ready for Doom 3, as long as they decide to make it compatible with the g4. You may need to overclock you cpus though. Check out http://www.bitsandpieces.info for some really good instrucions for that. As I will say in my MDD mod guide, the hard drives are the bottle necks here. Set up a RAID 0 for some serious speed. Hope you can use some of this info.
-Maestro
Top
#457487 - 01/21/05 06:36 AM Re:video card flashing. [Re: egoggle]
chrisrice Offline
I gave in a got a 9800.
what do you sugest for heat sinks.
and where can i find atiaccelerator.
i have a graphics card for sale if any one needs one.
Top
Page 1 of 2 1 2 >
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
Now Software Support
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.043 seconds in which 0.028 seconds were spent on a total of 14 queries. Zlib compression enabled.
