see i'm what you call code illeterait. i need someone to show me step by step. what i need is a video card that has an dvi and apples little monitor type (the name escapes me now) cuz i got one of thoes new 23inc monitors and my gforce 4 ti is close to not cutting it anymore. is it posible to put an ultra on it.
you are talking about ADC. The latter links listed above are step by step instructions for flashing your video card.
What computer do you have, and what are the specs? You are just trying to get a video card with DVI and ADC onto your current system so that you can use a 23" Apple Display, correct?
everone seems to get confused when i say this. the new monitors use a dvi port, and the old one's have a adc port. thoes are what i have. yes i am looking for a video card that has thoes ports so i can run my 2 monitors better.
i am using a dual g4 1.25 (not modified), with 2gb ddr sdram pc2600 ram, a nvidia gforce 4 ti 4600. the reason i am looking towards flashing is that the card i have is almost the best one i can get for a g4 with the ports i need. (or at least i think) this was just an option i was exploring.
I use to have that exact system, great computer...
I am currently running 2 DVI monitors that are 1600x1200 a pop. I am running the ATI Radeon 9600 (I am pretty sure). It has one ADC port and one DVI port. The DVI port in the back of the system is DVI-I (meaning that it carries both an analog and digital signal). The new Apple displays should be DVI-D displays, therefore it is possible that they will work with any ADC to DVI converter. However, I experienced problems with all of the converters except for the DVI Extractor II by Dr. Bott.
So, if I am not mistaken the Video card that is in your computer has one ADC and one DVI port, correct? If this is the case, you should be able to just purchase the DVI Extractor II, run that from the ADC port to one of the LCDs. Then, just run the other one directly to the DVI port in the back of your video card as it is.
I hope this helps. Did I understand you correctly? :huh:
Okay, the g4ti is a pretty good card. I would either overclock it or buy a 9800.I dont think you can flash that one with a higher version. But with some ram heatsinks and a larger gpu heatsink, you could overclock for better performance. Are you a gamer, if not I wouldn't bother getting a new card.
If you are a gamer, you need to stay on top of the video changes. Go with a 9800 pro and over clock to an xt. With ATIccelator II and some heatsinks as I said before will let you do that. The nice thing is that the price just dropped to 250 bucks. Buy the mac one and you won't need to bother with flashing because it doesn't save that much money anymore. Get it and you will be ready for Doom 3, as long as they decide to make it compatible with the g4. You may need to overclock you cpus though. Check out http://www.bitsandpieces.info for some really good instrucions for that. As I will say in my MDD mod guide, the hard drives are the bottle necks here. Set up a RAID 0 for some serious speed. Hope you can use some of this info. -Maestro
