Page 2 of 2 1 2
Re:Video ribbon connector [Re: jimmie] #457153 12/19/04 10:11 AM
P
photoworkplace Offline
P
I am assuming you are referring to the ethernet cable (cat. 5)
If that is to much of a pain get a firewire cable, cut the casing off and use the internal wire.
As far as a soldering iron goes, just take the tip and file it down until you get the right size, don't forget to re-tin the tip after filing.
Re:Video ribbon connector [Re: jimmie] #457154 12/19/04 10:35 AM
T
TJH Offline OP
T
Well, I haven't tried the cat. 5 idea yet, but I was referring to the ribbon cable, as it is near to impossible, as far as I can tell, to reliably splice the ribbon cable to get a good connection.
Great idea with the filing down of the tip, hadn't thought of that.
Post edited by: tjh, at: 2004/12/19 10:38
Re:Video ribbon connector [Re: jimmie] #457155 12/19/04 12:20 PM
P
P
If your piggybacking the new wire to the connector you don't have to "splice" into the ribbon cable
Re:Video ribbon connector [Re: jimmie] #457156 12/19/04 12:46 PM
W
whitlock Offline
Moderator Emeritus
Moderator Emeritus
W
What the ribbon cable allows is to have wires come from one board to another in a very narrow passage. If your mod will not have a narrow passage, just take wires from one board to the other. Remove the ribbon cable if you can. If your mod still requires a narrow space, then work with it, but if not go with straight wire, and no splicing required.
It should not be too hard, and I would suggest getting a 'solder sucker' that is meant to remove solder. Well, technically it's called a Vacuum Desoldering tool. Kind of looks like a syringe that you point at it and when you hit a button, pulls the hot solder into it. It's like $8 at Radio Shack. It will make removing the cable and ZIF connectors pretty easy. The part number is 64-2098 if you need it.
Canon Rebel XTI
Google Cr-48 Beta Laptop
Re:Video ribbon connector [Re: jimmie] #457157 12/19/04 01:00 PM
P
P
Don't forget you can always cannibalize a ribbon cable from something elise.
Even if it is a 30 wire ribbon, cut off the ones you don't need, or gang 2 10 together, to make do.
Page 2 of 2 1 2
