• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » Mods and Hacks » Peripheral Mods » What is this little brown cable?
Page 1 of 2 1 2 >
Topic Options
Hop to:
#457143 - 12/18/04 11:12 PM What is this little brown cable? [Re: jimmie]
TJH Offline
I've hit a dead end in my mod. On the lcd screen, an old kogi, there is a little brown "ribbon" type cable with about 21 wires in it. (I was a bit tired, I'll do a better count later) It connects the bottom vertical controller board to the horizontal controller board, but the wire is only about 1 inch and I need to make it about 6 inches.
Is there any simple extender that I can buy? Or am I stuck with making my own? Will just any type of wire be sufficient, or is there a place to buy some already made ribbon cable that I can just solder on? I have never really soldered much before, so for something this small would a 15W iron be sufficient, or something more? Thanks in advance.
Top
#457144 - 12/19/04 12:18 AM Re:What is this little brown cable? [Re: jimmie]
krusher117 Offline
I'm willing to bet that you won't find a simple solution to this one. I'd fabricate my own. Before you attempt it tho, call kogi http://www.4kogi.com and speak to one of their technicians. You may have some luck getting a little info out of them.
Post edited by: krusher117, at: 2004/12/19 00:19
Top
#457145 - 12/19/04 12:36 AM Re:What is this little brown cable? [Re: jimmie]
TJH Offline
Well, slight problem there is that Kogi no longer is in business, it was bought out by GVision a few years ago, and unfortunately all Kogi stuff has been discontinued.
As far as fabricating one: is a 15W iron sufficient? Any suggestions as far as that goes? Thanks.
Post edited by: tjh, at: 2004/12/19 00:40
Top
#457146 - 12/19/04 05:24 AM Re:What is this little brown cable? [Re: jimmie]
whitlock Offline
Moderator Emeritus
Anything that will melt the sauder to the contact points and wire should be enough. You really don't need a higher wattage iron for what you are doing anyways, because you could damage the board or ribbon.
Though if you find that it doesn't stick, try using a knife and scratch the top of the contact. Just barely enough, but it can help if you get a point where it just does not want to stick.
My suggestion is to take the ribbon out of the equation if you can and use wire strait from board to board. The ribbons are hard to come by and in case something happens, you will have the backup.
Canon Rebel XTI
Google Cr-48 Beta Laptop
Top
#457147 - 12/19/04 07:10 AM Re:What is this little brown cable? [Re: jimmie]
TJH Offline
Did a bit of practice soldering on an old ethernet card. But when I finally brought the lcd over to use I realized that there is no way that I'm gonna be able to solder onto the tiny, and very close together, leads. I think my best bet is gonna be to cut the ribbon in half, and splice in some other wires. So my next question is: how the heck do you get to the wires in this stuff? seems the plastic has a very high melting point and it makes it very hard to access the wires. What's the best way to get at those little copper wires inside? Any ideas? Thanks.
Top
#457148 - 12/19/04 07:55 AM Video ribbon connector [Re: jimmie]
photoworkplace Offline
Are you referring to the video feed ribbon cable?
Is there a strip connector on the end?
Just get some ethernet cable strip it and shove it into both connectors before you start cutting things up.
I do not have a picture in my mind of what the Mod is that you are working on.
But it is my practice to do none destructive investigation first, see if it works then make the permanent modification that will fit into the design.
Joseph
Top
#457149 - 12/19/04 08:07 AM Re:Video ribbon connector [Re: jimmie]
TJH Offline
Agreed, I haven't cut anything on the lcd yet, just playing around with some ribbon cable from an old PB that is extra. Not sure what you mean by the video feed cable, or a strip connector. The cable is a flat, brown, somewhat see-through cable with 20 copper (2 millimeter wide) wires in it. The connection on the end is a bunch of silver flat connections which plug into a little clip that is manually closed on the other side. I'll see if I can't get some pics up in a bit.
Edit: here are the links to the pics (didn't want to embed for people on dialup etc.)
http://members.cox.net/tj53/wire%20and%20connector.jpg
http://members.cox.net/tj53/ribbon%20wire.jpg
http://members.cox.net/tj53/connector.jpg
http://members.cox.net/tj53/solder.jpg
Post edited by: tjh, at: 2004/12/19 08:35
Top
#457150 - 12/19/04 08:59 AM Re:Video ribbon connector [Re: jimmie]
whitlock Offline
Moderator Emeritus
I've seen people do it before. It's possible, but you may need to practice some more, and possibly get a finer tip for your saudering iron to do the job.
Canon Rebel XTI
Top
#457151 - 12/19/04 09:05 AM Re:Video ribbon connector [Re: jimmie]
It would be my thought that if you cut the ribbon then take some new wire that you have melted the smallest bit of solder to the ends of, you could piggyback the extension wire onto the preexisting connector.
You would then do the same thing to the other side.
Make sense?
Also here is a link to a company that sells ribbon and connectors you could probably just go out and buy a longer one, as an option, (not as much fun).
http://www.fujikura.co.jp/elect_material/frame_h_e.htm
Top
#457152 - 12/19/04 09:15 AM Re:Video ribbon connector [Re: jimmie]
TJH Offline
photo- thats what I was thinking as far as splicing goes. big problem there though is that the copper wire inside is very brittle and the plastic, or whatever it is, on the outside is ridiculously durable, and I haven't yet figured out a decent way to get it off while keeping the wire intact.
whitlock- as far as soldering goes thats what I think I'm going to try first, as it would be the least destructive. But just wondering what you would suggest as a tip, or place to get a better one. The one I currently have is small, but certainly not small enough.
Post edited by: tjh, at: 2004/12/19 09:56
Top
Page 1 of 2 1 2 >
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
Now Software Support
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.037 seconds in which 0.023 seconds were spent on a total of 14 queries. Zlib compression enabled.
