• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » Mods and Hacks » Desktop Mods » Hardware Mods » Attempting The iPC...
Topic Options
Hop to:
#457067 - 12/09/04 02:33 AM Attempting The iPC... [Re: sweetpea2007]
Nubreed04 Offline
after recently seeing the winner of the Annual Mod Challenge on this site, i've been inspired to make my own iPC.
i was planning on just selling my iMac DV on ebay, but then the value of it dropped dramatically after the release of the G5s.
So i realized that it would be more valuable to build a pc out of it. (ends up saving me $200+ in parts if i turn it into a pc)
my question:
is there a way i can keep the internal monitor instead of intalling a LCD like shown in the iPC on this site???
does anyone know what kind of wire connection is linking the internal Monitor to the logic board?
i read somewhere online that it was an older VGA connection, but i'm not sure???
Top
#457068 - 12/09/04 03:30 AM Re:Attempting The iPC... [Re: sweetpea2007]
oojacoboo Offline
I think the reason he used an lcd instead of the crt is because the crt was broken. Therefore, he used a lcd because he couldn't get a crt. There shouldn't be a problem with using the stock crt in the unit so long as you have space for everything else.
As I understand it, it is a vga connector that connects to the logic board. Exactly how it will fit I am unsure. Maybe someone else will know.
Also, while doing this mod, don't forget to take plenty of pics and make a mod guide for everyone.
Mac Pro Quad 2.66 - 4GB RAM
Quad 19" Widescreen LCDs
Accessorized to the Hilt
Top
#457069 - 12/09/04 10:11 AM Re:Attempting The iPC... [Re: sweetpea2007]
whitlock Offline
Moderator Emeritus
An advantage of using an LCD is that you free up a lot of internal space, and also cut the heat back by quite a few degrees.
If you want to go with the internal display, you will have to keep the power boards, and route the power from the power supply to the board. The board would need to be a small form-factor and be mountable to the bottom (which is not hard). After going with the board, you will need to route the video cable that goes into the logic board and plug it into the VGA on the back.
Should work, thoughI think modyourmac could doublecheck since he could probably grab one at random and check to see if it works. I can't imagine it not working like that, and at the very most, you will just have to re-route the VGA cable.
Canon Rebel XTI
Google Cr-48 Beta Laptop
Top
#457070 - 12/09/04 10:52 AM Re:Attempting The iPC... [Re: sweetpea2007]
zenstate Offline
Loc: Vancouver, BC Canada
I honestly can't understand how anyone could change a mac to a pc. its simply insane.
I will never understand how anyone can sit and use a wintel system without barfing all over themselves.
sorry, had to say it smile
2.94TB Total Storage
Top
#457071 - 12/09/04 09:40 PM Re:Attempting The iPC... [Re: sweetpea2007]
whitlock Offline
Moderator Emeritus
Ever work a 8-5 job? You gotta do what you gotta do.
Canon Rebel XTI
Top
#457072 - 12/09/04 10:01 PM Re:Attempting The iPC... [Re: sweetpea2007]
krusher117 Offline
Heres a bit of useful data from a forum post on macs2u.com
you just take the plastic cover off the base, and the CRT connector is sitting there right in front of you!
It has a 15 pin connector screwed in, which you remove and then connect a mac to PC VGA adapter and you are off!!
Heres the link to the discussion
http://www.macs2u.co.uk/cgi-bin/simpleforum.cgi?fid=01&topic_id=1073155044
Top
#457073 - 12/09/04 10:19 PM Re:Attempting The iPC... [Re: sweetpea2007]
whitlock Offline
Moderator Emeritus
I know on the Rev. A-D that the 15-pins were there, though the DV's plugged into the board via a connecter going through the metal plate sepperating the logic and analog boards.
You should be able to rewire that connector using thin wiring, and unfortunatly you will have to forget the VGA port, as that's part of the logic board.
Canon Rebel XTI
Top
#457074 - 12/10/04 07:21 AM Re:Attempting The iPC... [Re: sweetpea2007]
Nubreed04 Offline
thanks for the info guys...
i'll let you know how it turns out! laugh
and as for why i'm turning it into a pc... a 400mhz G3 is so slow compaired to my dual 1.25 G4... (plus its the cheapest way for me to network 2 computers that can play the newer video games...hehe)
Top
#457075 - 12/10/04 07:28 AM Re:Attempting The iPC... [Re: sweetpea2007]
oojacoboo Offline
make sure and take plenty of pics for a mod guide! laugh
Top
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
Now Software Support
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.048 seconds in which 0.035 seconds were spent on a total of 13 queries. Zlib compression enabled.
