• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » Mods and Hacks » Laptop Mods » Case Mods » G4 Graphite ZIP bay mod
Page 1 of 2 1 2 >
Topic Options
Hop to:
#456748 - 10/27/04 05:51 AM G4 Graphite ZIP bay mod [Re: Saduyre9de]
grasal10 Offline
I have a G4 Graphite Mac with a DVD rom and a vacant bay which upon close examination seems to only accommodate space for a ZIP drive. I wanted to add a DVD burner in the area the ZIP drive bay. Has anyone done such a modification. Regards, Graeme
Top
#456749 - 10/27/04 11:14 PM Re:G4 Graphite ZIP bay mod [Re: Saduyre9de]
krusher117 Offline
The zip bay will accomodate a 3.5 inch drive, however it is possible to dremel the aluminum and create a support structure inside to house a 5.25" drive. I have run a hard drive in that slot before (note to self, next time don't fry the drive by not ventilating properly). The extra power and IDE cable is all set up for you. All you need to do is make room. It's very simple, but I haven't seen it done. You may be the first. Can you take pics and make it a guide for others?
Post edited by: krusher117, at: 2004/10/27 23:15
Top
#456750 - 10/28/04 12:17 AM Re:G4 Graphite ZIP bay mod [Re: Saduyre9de]
whitlock Offline
Moderator Emeritus
I know I'v seen a mod for this, though after 40 minutes of scouring, I could not come up with it. But using Dremel tool to the metal, dropping a couple pieces of threaded metal down from the top bracket, making sure that they are tight will do the trick. The issue is with the plastic.
With the plastic front cover, you would need to use the Dremel at a slow speed to cut, use fine grade sand paper around the edges. You will not have a nice looking faceplate, unless you can get another plate from eBay or a fellow G4 tower, which could be butchered (a shame, I know). You could then cut that face down to fit where the open slot is, glue it, and you would have a flush faceplate. I would imagine that would work for you.
I can't think of anything else to add. Krusher, you have any suggestions on the plastics that I may have missed, or dropping the metal supports in?
Canon Rebel XTI
Google Cr-48 Beta Laptop
Top
#456751 - 10/28/04 04:05 AM Re:G4 Graphite ZIP bay mod [Re: Saduyre9de]
krusher117 Offline
I think the mod will be easy to do. Making it look good may be another story. When I had to cut a shape, I used a drill bit in my Dremel. Do they make a sideways cutting tip? I dont recommend using a drill bit because it will look terrible.
Top
#456752 - 10/28/04 05:00 AM Re:G4 Graphite ZIP bay mod [Re: Saduyre9de]
TutAnGeek Offline
The answer is that you can't.
Take a look at where your RAM is on the board, when the case is shut. There is not enough clearance for a larger bay. Even if you were to dremel a bigger hole, and make a new mount, you wouldn't be able to have any RAM installed, and have the case shut. That is, unless you came up with some sort of crazy scheme to move the RAM (far easier said than done, I don't expect to see it wink ) :P
Top
#456753 - 10/28/04 05:03 AM Re:G4 Graphite ZIP bay mod [Re: Saduyre9de]
grasal10 Offline
Hi. Thanks. It doesn't look impossible but I'd have to be careful not to butcher it. Creating new mountings for both DVD drives would be an issue. Graeme
Top
#456754 - 10/28/04 06:12 PM Re:G4 Graphite ZIP bay mod [Re: Saduyre9de]
TutAnGeek Offline
I repeat....
Try gluing on a piece of cardboard to expand the width to that which it would be when a full size drive is there. Close the case. You prubably will experience difficulties closing it. When you open it, if you closed it fully, you will find your cardboard is all out of place. If you put wet red paint on it, you would find your RAM covered in red paint.
Don't bother cutting. It won't work.
Top
#456755 - 10/28/04 08:53 PM Re:G4 Graphite ZIP bay mod [Re: Saduyre9de]
grasal10 Offline
Hi TutanGeek. I had a look and my RAM actually goes above the top DVD Drive however, I see your point as making the bottom (ZIP) bay larger is impossible because it is the heat sink for the accelerator that actually butts against the lower bay. You are right ...it is impossible......Drat.
Many thanks Graeme
Top
#456756 - 10/28/04 10:46 PM Re:G4 Graphite ZIP bay mod [Re: Saduyre9de]
whitlock Offline
Moderator Emeritus
On the older, original, G4 towers the ram was centered in the case, and at the top so it goes above the top bay. And on the Graphites I could have sworn they were in the same position, whereas the newer cheese grater G4's had their RAM placed beside the heatsink. If you could send a pic of what your talking about Tutan, I'd appreciate it, but having a hard time visualizing it, since the RAM would hit the original optical drive if it were that low.
Canon Rebel XTI
Top
#456757 - 10/29/04 01:13 AM Re:G4 Graphite ZIP bay mod [Re: Saduyre9de]
TutAnGeek Offline
I sold it. It's possible that it was the heatsink. Whatever it was, it would still be impossible.
Top
Page 1 of 2 1 2 >
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
Now Software Support
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.040 seconds in which 0.021 seconds were spent on a total of 14 queries. Zlib compression enabled.
