#456177 - 08/05/0412:00 AMSilence mod for Quicksilver-series G4
[Re: Anonymous]
Anonymous
Here's some info on replacing fans in the G4 Quicksilver. What's cool is the guy pulled out the front speaker (now mounted elsewhere) and replaced it with a LCD temperature monitor (backlit) connected to the CPU. He arranged the monitor so the temperature shows the speaker hole.
I'm sure this mod could be modified to other uses and other G4s.
Loc: Cyberspace Sector USA
hey magnus,
that is a sweet mod. Just wish I had a quicksilver g4 to perform the mod on....
Here is another suggestion: If any of you have any unused 5 1/4 bays you should install a smart panel. The features are: blue backlit dual temperature/ fan rpm lcd display, a temp selection switch, two fan speed adjustments lit by two blue leds per control, and 2 usb 2.0 ports.
maclover1986
Post edited by: maclover1986, at: 2004/10/30 05:01
Post edited by: maclover1986, at: 2004/10/30 05:02
Thats a cool mod. Although it would be so much better if someone would put it on the desktop of the finder. Oh wait, Temp. Monitor and Hardware Monitor both do that! They are even customizable. I always have it running lately as I have been testing my g4 overclock and Raid setup. I love it. By the way, there is a shareware version-ITS FREE! -Maestro
