afraid that the drop shadow is not a possibility for these icons as I do not have the master files. A darker grey, would not match the rest of the site. It is the same color as the grey background.
erase the grey using the stamp tool/clone tool (depending on what program you are using) and then create a new layer w/ the text. drop the shadow on that. it should work after that point. i had to deal w/ a lot of issues on my site about not having the master files. in all seriousness, it should be lime green with header graphics in the 90kb range. that would not have been good. the footer was like 45kb. btw, i'm off topic. well, good luck working on those icoms.
and when are you going to change the red triangles to the right used as bullets
