make sure you test the led before putting it in because it may be a different shade than desired. thats from experience. made that mistake with some mods before, but thank goodness it was something that simple. they all look the same, but one orange may be slightly different, even thought they look exactly the same when they are dark. eh, maybe i'm just complaining about nothing, but i do that...
Also, if you want to get some good LED's without spending the ridiculous prices (ala RatShack) check out LS-Diodes. I always use them, and have yet to get bad product/service...
I've found the color on their LED's to be excellent, and at less than $.60 cents an LED, they have saved me some serious cash!
What size LED's are in the 3rd generation 3mm.. 5mm...? what volatage.. mcd...type??? any help is appreciated as I'll do the work myself and of course post it here if sucessful! B)
Yeah I'm looking for these too.. I don't want to send my ipod to anybody, I want to do this myself.. I'm looking for the size and voltage for these L.E.D.'s, if anyone knows, thanks alot.
Well one mod that was posted on this site (It may have been in foarms) Is just to take a gel (like the ones in theatre lights) and cut it to the size of your screen...
