no, but i will make one, except my digi cam is at my sisters. if you know how i can take a snap shot that will be big enough with my iSight, i would be glad to take a few.
does it give you a 'picture over 499 pixels' error? If you edit your post and try again and it gives you the error again, its won't even display the attach image option for the 3rd and subsequent tries. Solution is make your image smaller, delete the post and start over. Sorry but thats how it works :dry:
