My friend is so sacrificially giving me "a piece." Turns out its a Powerbook 520c. So I was thinking about expiramenting with some casing mods. Any ideas out there to get me thinking before I get it?
EL sheat? Theres enough room in those to add an inverter and cables so you could mess around with some EL sheet/sting.Power might be a little tricky but the thing supports two batteries. Maybe try adding a window to it? I don't think PC modders have tried either of those ideas on a laptop.
Course you could take a look at Apple Design (inter-library loan will probably be the only way) and work with a trashed Apple Idea.
