• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » Mods and Hacks » Laptop Mods » Hardware Mods » Battery Life Extension Mod?
Page 3 of 3 < 1 2 3
Topic Options
Hop to:
#454939 - 06/07/04 11:38 AM Re:Battery Life Extension Mod? -FOUND IT [Re: iraszl]
elakazal Offline
They may look like they are standard AA cells but that is only because they are the same size. The
internal structure is most likely quite different.
Nah, I'm pretty sure they're basically just rechargeable AA's when it comes right down to it. I've successfully replaced the stock cells with actual rechargeable AA's, and I've seen websites illustrating the same for various laptop batteries. There may be some obscure difference, but if AA's work, then they're the same by me. If it quacks like a duck, then it probably is.
Top
#454940 - 06/09/04 03:16 PM Re:Battery Life Extension Mod? -FOUND IT [Re: iraszl]
mark Offline
elakazal wrote:
Actually, the AA battery idea isn't so far fetched. I haven't opened up an recent laptop batteries, but I can attest that at least the PowerBook 5300 and the Newton MP 2000 all use standard rechargeable AA cells in the batteries. I know this is the case for many PC laptop batteries as well. Replacing the cells in my Newton battery gave it life again, albeit an unimpressive amount of life, in part because I used really cheap rechargeables.
Most battery packs use standard cells, its just some are more standard than others. best thing to have for a recelling is a good ruler and a copy of the Digi-Key catalog.
Anybody here open up an iBook battery? If it's readily done, I'd like to re-cell my dead one.
I think it has but I don't know where I've seen it. Get a good sharp xacto knife and run it around any seams you find. With luck that should break the ultrasonic welds and give you access to the cells. At least thats always been the general rule of thumb for recelling.
Top
#454941 - 06/14/04 01:47 PM Re:Battery Life Extension Mod? -FOUND IT [Re: iraszl]
Woodpecker Offline
I'd love to "re-cell" one of my Pismo batteries, but I will most likely by an aftermarket "extended Life" batt. Two actually that is one of the cool things about the "Pismo" you can remove the drive bay and install a second Batt. I will run that "Pismo" until it melts great machine, I have a DVD drive, a Zip drive, and a floppy drive for it. Here is the cool thing I found a web page that talks about moding a Dell combo drive to fit in the Apple removable bay, if I go down that road I will keep you posted.
The Pecker
Post edited by: woodpecker, at: 2004/06/14 19:42
Top
#454942 - 06/14/04 06:18 PM Re:Battery Life Extension Mod? -FOUND IT [Re: iraszl]
whitlock Offline
Moderator Emeritus
the pismos were completely different. they are your more modern design. they are much too light to be like the 5300 and other older batteries. the pismo is just too nice. i'd go down to the local battery store and see if they have the appropraite cells there.
Canon Rebel XTI
Google Cr-48 Beta Laptop
Top
#454943 - 06/15/04 03:49 PM Re:Battery Life Extension Mod? -FOUND IT [Re: iraszl]
mark Offline
You need to be sure to get exactly the same cells if you're recelling a lith-ion battery. There's some electronics in there that won't play nice with cells that aren't exactly the same as the stock ones. Tho' if you want your system to melt...
Top
#454944 - 06/15/04 11:33 PM Re:Battery Life Extension Mod? -FOUND IT [Re: iraszl]
whitlock Offline
Moderator Emeritus
yes. if you use the wrong ANYTHING, it will just fry either the power management unit, or the battery itself. luckly the pmu can be had from a scrap pismo to just above $100. you have to remove all of the plastics on it to acheive that one. i've replaced about 7 of them. can't remember exactly, but that's about right. when playing with non-approved equipment, always match, like anything electronic.
as for ibooks, havn't seen a recell on that, but it doesn't mean someone hasn't tried it. i'll look around.
Canon Rebel XTI
Top
#454945 - 06/15/04 11:38 PM Re:Battery Life Extension Mod? -FOUND IT [Re: iraszl]
whitlock Offline
Moderator Emeritus
well, here are the cells:
http://www.techfreakz.org/pcgabp52/?slide=21
unfortunatly, i am at work and the firewall blocked it (BLAST!)
for any other info, try :
http://www.dragonsoftware.co.uk/sleepcentre/threads/f915b46da6c77fa39cb7d7b665f2f260.html
Canon Rebel XTI
Top
#454946 - 06/23/04 04:31 PM Re:Battery Life Extension Mod? -FOUND IT [Re: iraszl]
karl Offline
Fuel Cells on a Laptop. This could be interesting.
[url]http://www.pcworld.com/news/article/0,aid,116591,00.asp[/url}
Post edited by: Karl, at: 2004/06/23 12:33
Top
#454947 - 02/28/05 11:05 PM Re:Battery Life Extension Mod? -FOUND IT [Re: iraszl]
ubergeek89 Offline
scottk wrote:
I could not figure out how to open up one of the ibook batteries for the clamshell. I ended up spending $90 and getting a new one.
And now the darn thing has a motherboard problem and it won't charge.
It just never ends.
What you have is a dead PMU/Charge board (a small board located on the front left of the iBook that controls charging) a simple fix (may not work but its worth a shot) to this could be a PMU reset on the clamshell, above the power button where it slands down by the display hinge, there is a small button. remove your battery and power supple, wait a few seconds, press this button with a paperclip, wait 5 seconds till you re install your battery and power supply and it should work, if not start hitting ebay.
Mobile-2.2Ghtz Core 2 Macbook, 4GB ram, 160GB HDD
Server-Dual 1.42 MDD G4, 1GB ram, 4 random hard drives.
PC-C2D 2.4Ghtz, Asus Commando, 2Gb ram, 3 hdd's in raid 5, 8800GTS.
Top
#454948 - 04/03/05 09:47 PM Re:Battery Life Extension Mod? -FOUND IT [Re: iraszl]
dead13 Offline
i just opened up my old ibook battery from the top and the cells look like 2 aa batteries wrapped together there are 6 of them if youu want a pic or part # on the cells i'd be happy to send them.
Top
Page 3 of 3 < 1 2 3
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
Now Software Support
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.045 seconds in which 0.030 seconds were spent on a total of 14 queries. Zlib compression enabled.
