IMO, waste of money. You can get 700MHz G3 iBooks for $700-$800. That can get you a larger screen, better battery, moden ports, and better drives. Plus you get the faster bus and a while lot more memory. Unless you get one dirt cheap or free, forget about an upgrade
I also have a PowerBook 1400/166, just asking to become something useful. Getting WiFi to work on this thing has always been a dream of mine, but from what I can gather, is more like a nightmare.
For starters, the only WiFi cards that I've ever heard of working on a 1400 are those with an Orinoco chispet. While drivers are available, you'll need OS 8.6 or higher to use them. So, after having spent all that money, what do you get? A PowerBook that runs like treacle, that's what. Even OS 8.1 causes the old 1400 to sweat.
Personally, I'm leaning more in the direction of a digital picture frame, but perhaps with more functions. For instance, why not also use it as a CD/MP3 player? Or a wall mounted personal digital assistant. The keyboad could be mounted in a flip-down panel and the trackpad could be attached to the frame.
The other idea I'm toying with is a carputer, but that would be less useful, unless somebody can prove me wrong about the WiFi issue.
In the meantime, any more oringal suggestions are welcome.
The Orinoco is the right way to go. It's a high quality card that has a good warranty to back it up. Also, if you plan on running OS X (using ex post facto) you could also run a card that has a Broadcom chipset. Unfortunatly, there are not too many cards that run those.
Another that will work with your machine is a Buffalo Technologies card. From personal experience the Buffalo cards are crap. Yeah, I wouldn't endorse them with a ten foot WiFi pole. But if you want to, that is cheap card you can try on your PB.
Now for your WiFI issue. After updating to OS 8.6, you will get internet access, but it's not going to be very fast. It's going to act like if you plugged a NIC into it. Pretty much, your limited by your machines speed. So if going online is high priority, then get a card. If not, go with one of the mods.
The 1400 makes a good picture frame with the right software. They are not too hard to modify, considering all you will need are some Torx screwdrivers to take apart. The carputer, I'm sorry, would not be a good idea. It will just run slow, and not be too impressive. A good carputer, in my opinion, should be atleast a G3. With the speed, and processor, you can run OS X where there are some *nix apps made that would look great in a car.
I'd go for a picture frame that can play MP3's.
Actually, whitlock and mark, the serious problem with the 1400 is that you can only use 16bit pcmcia cards in its slots. This limits you to only the original lucent/orinicco cards, and anything else that is 16 bit. There are ways to get many cards to work on powerbooks, but for the 1400, it must be a 16 bit card. The 1400 works nicely in a picture frame (i did one), but make sure that you get ample flash storage so that you don't have to have a loud hard drive spinning.
And whitlocck, the PPC will do fine playing CD's, and if you put in enough ram and set up a nice cache, you can have nice MP3's too. Also, it's a pain in the ass to set up a simple "carputer" on OS X.
It is true that you can only use the 16bit cards, because that was an issue that plagued Mac technicians for a long time. That is why finding decent USB or Firewire cards was such a pain, because you had to line up a working chipset as well with the bus. I had a vendor that screamed one time when I asked if he had a Firewire card that would work with a 5300cs, and he screamed, literally, screamed at me. I dropped that vendor, and just decided to pay full price w/ MacResQ.
With OS X, there are more apps available to setup a "carputer", as opposed to OS 8.6-9.2.2. I cannot name any apps made for a "carputer" in OS 9, because I could not find any after a few minutes of searching. Atleast I can find *nix applications for OS X. Considering you can put a slim install on there and run a better version of iTunes, like one running party shuffle, is more than enough to say that the possabilites are endless when running X. Not to mention you can compile apps if you find one that would work better. That and speakable apps work better in X than in 9 in general.
And whitlocck, the PPC will do fine playing CD's, and if you put in enough ram and set up a nice cache, you can have nice MP3's too. Also, it's a pain in the ass to set up a simple \\"carputer\\" on OS X.
Who said the PPC would not play CD's well? A pox on the person that said that in this thread. Seriously, no one in this thread mentioned that the PB would not be able to play CD's very well, that was your own statement. Watch how you structure your phrases Tutan, because that was directed at me, if you were wondering why I'm irked right now.
Post edited by: whitlock, at: 2004/11/01 03:57
This implies that you don't believe that a 1400 can't decode MP3's well enough. A "carputer" could include audio playback, or navigational purposes. Surely the navigation couldn't be limited by the processor, so therefore, I imagined that you were implying that the 1400 wouldn't be able to decode audio fast enough.
Have you tried setting up a "carputer" on OS X, whitlock? It seems to me that many people are under the impression that "it works on "*nix" so therefor I can download the source and compile it on OS X!" Guess what? It's not like that. Sure, there are many cases where this may be true, but there are also many more where it takes a fair bit of tinkering and patching to get the program to compile and run decently.
iTunes has a huge GUI that makes it easy to use from a mouse and keyboard. How does that make it more implementable in a "carputer" set up?
I would like to clarify two things though.
One of which was my general statement about the G3 being a better "carputer". That is true. It's a better machine overall, and depending on which G3 PB you get, you can get a DVD drive to play movies as well. Nothing was said about the 1400 having issues with MP3 playback. If you are going to install a carputer, it would make more sense to install a machine that has more edge to it than an older PB.
And I have never tried setting up a "carputer" with OS X. I never saw the point of it until everything is integrated and you can access the inboard dash computer to tweak fuel settings as well. A good old MP3 deck is good enough for me at this time. I have seen a few good home brew Linux 'carputers' and MP3 players throughout the years, and decided that since people already have the apps made for atleast Linux, a good recompile for a known good piece of software is worth it, as opposed to using older OS 9 legacy applications that do not have a driver or car friendly interface.
Pimp My Ride had a 'carputer' that ran Windows. The first thought I had was that it was going to crash something on the way home.
