I am trying to create a VPN server on a Mac at my school (I'm a teacher) so I can access the network from home and print to our document server. I see how to connect to a VPN server from a Mac, but not how to set up a VPN server.
I do not have OS X Server, so I am looking for alternative ways to do that. I am fairly new to using Macs, especially their networking capabilities so if you can help, please try to give me all the details, including the simple ones.
Thanks, I downloaded it and set it up. It is very straightforward, but I am still having trouble connecting. The Windows message is telling me that Windows is allowing the connection but a remote firewall is blocking the connection, and to make sure port 1723 is open. Could it be port 1723 on the Mac (where the VPN server is located). My Westell modem has a firewall but I logged in an all VPN connections are set up to passthrough.
You shouldn't be setting up a VPN server on your school's network, the school should already have a VPN in place. Most likely they'll provide you with a client to connect with, and logon info. Once you log on, it's as if your machine is on the school network directly, and you can simply log into your mac or any other file server and transfer files as you need.
#478451 - 11/20/0903:00 PMRe: How do I set up a VPN server on a Mac
[Re: SgtBaxter]
neil
Neil Ticktin
Loc: Westlake Village, CA
And, to reiterate what Bryan is saying, if you are setting up something like this ... make sure that the IT dept for the school district knows in advance. That could save you (and them) a whole lot of heartache.
The easiest way to use the VPN Server Configurator. The program itself installs and configures the VPN Server. The user need only specify the planned number of connections. You can use it even with the dynamic IP. http://www.greenworldsoft.com
