#454291 - 11/09/0903:22 PMRe: 10.6.2 is live!
[Re: starmillway]
I consider myself very lucky that I've never had a problem with any OS upgrade/update from OS 7.1 all the way through 10.6.2. The only problem that I did have was with 10.5 and the Application Enhancer conflict that I was unaware of. Once that was identified and I removed APE, the upgrade from Tiger to Leopard was uneventful.
Good lord, what a list. I'll probably wait until just before the release of 10.7. Then I'll install 10.6 and all the updates.
Seriously, for all the SL envy I suffer? All I have to do is consider anything that would jack with my work flow. The way our deadlines run ~ We don't call 'em Drop Deadlines for nothin'.
Sigh. I'll just bask in everybody else's glow. Thank you for making that easier, kate.
#454305 - 11/09/0903:52 PMRe: 10.6.2 is live!
[Re: starmillway]
If your system is running well now and you are confident in it, then slam away. If you are running legacy software or have a bunch of old fonts, etc lying around then your mileage may vary. There is the option to install Rosetta if you have to rely on PPC apps. Of course, there is always TM to fall back on.
#454306 - 11/09/0903:54 PMRe: 10.6.2 is live!
[Re: starmillway]
MikeSellers
I'm not into titles
Loc: Alpharetta, GA
Originally Posted By: starmillway
Fonts fixes provided for:
* an issue with font spacing * an issue in which some Fonts are missing * font duplication issues * an issue with some PostScript Type 1 fonts not working properly
I read about some of the postscript font glitches, which is one of the reasons I switched back to Leopard. I wasn't having any problems but didn't want some glitch to happen in the middle of a big project.
