ChrisN
Enjoy every sandwich...
Loc: Cal.
My computer/browser/ftp client loses the ability to resolve certain urls.
My gear: iBook G4 1.33 w/10.4.11
Scenario: url for greenfrogmarket.com resolves just fine. Upload files with CyberDuck to that domain. Works fine, at first. Then, the ftp connection times out and will not resolve. It will not connect to that ftp server again, no settings have been changed or altered. Next, the url in Firefox or Safari for greenfrogmarket.com also will not resolve. Other domains using Cyberduck connect perfectly. Other websites using any browser resolve normally. Transmit also does not resolve the ftp connection using all the correct settings.
This same scenario has happened with three different internet connections. At first each internet connection works fine. Then upload files via ftp, then nothing works for the greenforgmarket.com domain on this computer. Other computers can view the site without a problem.
Attempted fixes: Ran Onyx clearing internet caches, permissions, full routine. Used Software Update applying the appropriate updates including a Security update. Re-ran the 10.4.11 combo installer. No joy.
I do use a Belkin wireless usb device since my Airport card inside the iBook went bad. Don't think this is the problem since I tried an ethernet connection from the same internet source with the same results.
Any ideas? I'm in a bind since we have a big remodel project going at one of our stores and I am supposed to be doing frequent updates to our site.
This is from the same machine?
To test Michael's DNS theory, if you don't have the files I mentioned above try putting 4.2.2.3 and/or 208.67.222.222 into your Domain Name Server settings in Network for the interface you're using.
Edit - In Terminal type "sudo crontab -l" (the letter L, and minus the quotes), hit Return, enter your password. It should return "crontab: no crontab for root". Anything else and your DNS settings have been compromised.
Phosphor
An unreasonable man
Loc: Lancaster PA USA
Originally Posted By: Reboot
[quote=ChrisN]To test Michael's DNS theory, if you don't have the files I mentioned above try putting 4.2.2.3 and/or 208.67.222.222 into your Domain Name Server settings in Network for the interface you're using.
While you're at it Chris, if you haven't before, have a thorough look at OpenDNS.com.
I'll double Kate's money if you can show me when I said no Trojans, and the DNS Changer is not a virus. I'm not going to pollute this thread by discussing this anymore, we've beat this horse already. Please do the same.
And what does clarified butter have to do with anything?
