or much of anything else. The screen has become "big" so that I can only see a small part of the screen. I can't slide the on because it is blelow my visibility.
So resetting by holding sleep and home button for ten sconds does a restart but it only puts me back into the same place. I can see the eyeball of my dog (she is my wallpaper) but not much else.
What is the next line of reset? Bummer that I took some notes at a seminar this afternoon that I would like to use.
#453370 - 11/03/0904:49 PMRe: My iPhone won't phone
[Re: polymerase]
carp
Dino's are Babe magnets
Loc: Hawaii
Bummer
Friend has a iPhone 3Gs , he showed me at the top of the phone there was a small hole that you can insert a paper clip - this does a hard reboot . Check your manual first before you stick something down that hole ! ! He was pointing to the jack hole for the head set <- wtf
Restored from iTunes totally reset. Still no joy. The phone starts then the screen does this enlarge thing so I can still only see a third of the screen.
I figured it out by googling which I should have done from the beginning. Fix here. Funny, all it was that I had the triple tap zoom screen on. If you don't know how it got on then you don't know how to get rid of it.
The moderator who moved this cancelled my reason for using this forum. Quick snappy answers. Thank you all who helped me and have helped me through the years.
MacBeemer was right. The moderators or moderator who moved this is a supreme jackass. This is my last post. Thanks for the fish. I hope to hell I don't ever regret this and log in here again.
The moderators might realize that this forum is not Neal's. It's not the moderators. The forum is what it is. It is the users. Each and every one. Each one that should be treated with respect and not whined at the way MacBeemer was.
