My G4 tower shipped initially with one 128 (if I remember that far back).
Yeah, the G4 tower did. That model of PB came with 256 in the 867Mhz and 512 in the 1Ghz model. I just checked the manual to be sure, it came with 1 256M chip.
#449688 - 10/12/0902:06 PMRe: This is how My Tibook locks up
[Re: Jim_]
GAHeroine
The Greatest American Heroine
Loc: Time traveling in 1980
I had it repair permissions. here's what it came up with.
Repairing permissions for “B's Hard Drive” Determining correct file permissions. Group differs on ./private/etc/cups/certs, should be 26, group is 0 Owner and group corrected on ./private/etc/cups/certs Permissions corrected on ./private/etc/cups/certs Group differs on ./private/etc/cups/classes.conf, should be 26, group is 0 Owner and group corrected on ./private/etc/cups/classes.conf Permissions corrected on ./private/etc/cups/classes.conf Group differs on ./private/etc/cups/cupsd.conf, should be 26, group is 0 Owner and group corrected on ./private/etc/cups/cupsd.conf Permissions corrected on ./private/etc/cups/cupsd.conf Group differs on ./private/etc/cups/ppd, should be 26, group is 0 Owner and group corrected on ./private/etc/cups/ppd Permissions corrected on ./private/etc/cups/ppd Group differs on ./private/etc/cups/printers.conf, should be 26, group is 0 Owner and group corrected on ./private/etc/cups/printers.conf Permissions corrected on ./private/etc/cups/printers.conf Group differs on ./private/etc/cups, should be 26, group is 0 Owner and group corrected on ./private/etc/cups Permissions corrected on ./private/etc/cups Group differs on ./private/var/spool/cups/tmp, should be 26, group is 0 Owner and group corrected on ./private/var/spool/cups/tmp Permissions corrected on ./private/var/spool/cups/tmp Group differs on ./private/var/spool/cups, should be 26, group is 0 Owner and group corrected on ./private/var/spool/cups Permissions corrected on ./private/var/spool/cups The privileges have been verified or repaired on the selected volume
That's normal, it will probably show the same thing if you reboot and run it again. It has to do with security for the cups printer engine. Don't have time to explain, gotta run, just trust me, and it doesn't have anything to do with all the problems you're having.
Pull the loose RAM chip before we try anything else. Thx.
#449844 - 10/13/0911:54 AMRe: This is how My Tibook locks up
[Re: Jim_]
carp
Dino's are Babe magnets
Loc: Hawaii
LOL
I used to work with a old Japanese guy , one of them left circle , right circle old school attitudes . Anyway he always says to everyone "you just think you do" with no explanations - drove us nuts
