MikeSellers
I'm not into titles
Loc: Alpharetta, GA
Originally Posted By: PChaterosx
Originally Posted By: MacBozo
Of course, you have to be comfortable with opening up the case yourself, or find someone who will do it for you for a fair price.
I think I can do it. It can't be THAT hard, can it?
Guide for replacing hard drive. You'll need a torx 8 screwdriver. If you don't have one, you can get one at Sears or search online.
Do you have an external hard drive for backups? Is so, you could install a system on that, boot from it, migrate all your files to it and run the computer from that and see if the lockups still occur. If not, then you can be pretty sure it's the hard drive. You could just have a few bad sectors on the hard drive and doing a zero-all-data erase on the hard drive could fix your problems. Not the best solution but more economical.
I don't disagree about OWC, necessarily, Michael, but dealram lists all of the RAM available, including from OWC--so you can judge what's the best for your needs.
