I was trying to change my avatar picture, but kept getting a message that I wasn't doing it properly. First, "Improper picture type"--it's a plain old jpeg (and there's no impropriety in it, believe me!). Then when I try again, it says, "It does not appear that this was submitted from the proper form." What's am I doing wrong?
So, you're saying that linking to homepage.mac.com/youraccountname/.Pictures/filename.jpg doesn't work? Is it 75x85 pixels or what ever it's supposed to be?
Your computer is forever screwed more like it. You pasted in "http://155.52.95.150/666/billy.jpg" into the location of your avatar and then clicked "Submit" down on the bottom and it did not stick?
Once you click submit the new avatar should be showing right there. Now that would be weird.
