#445194 - 09/17/0904:48 PMRe: Choice of trials...
[Re: carp]
keymaker
I invented modding!
That's not what Judge Goldstone found, no...
No that is exactly what the Judge found .
No, that's not what he found.
Yes it is natural for Hamas to lob rockets at civilian targets , they do that all the time.
No, the motive you ascribe to it is not a natural inference,
Well, that's uncorroborated.
So is the 1417
No, the 1417 is corroborated.
fortunately their rockets did not hit a crowded market or populated centers
Well, it's impossible to aim them at any particular target.
numbers onlys comes into play when it goes to court as in counts of crime 3 -vs- 1417
Like I said - there's a recommendation for the confirmed Palesinian deaths to be prosecuted but not uncorrorated ones on the other side because prosecutions have to proceed from a prima facie case.
#445196 - 09/17/0904:58 PMRe: Choice of trials...
[Re: six_of_one]
keymaker
I invented modding!
Prove it. The deaths are presented as fact in the report.
Well, what he says in the report is sourced in the text or in a footnote. Corroboration exists when there's more than one source for the information.
your response to Carp earlier you stated the Commission did not find that Palestinians were deliberately and intentionally targeting civilian populations.
I believe the rocket fire was intended to put fear into civilian trespassers but with no guidance systems the charge of wilful killing could not be made out.
#445217 - 09/17/0906:55 PMRe: Choice of trials...
[Re: keymaker]
carp
Dino's are Babe magnets
Loc: Hawaii
That is the most crazy statement I ever heard - Gheees big guy your better then this .
You don't fire dumb rockets into a civilian area to "just" place fear - without even thinking the rockets will kill some civilians <-- shear insanity
I believe the rocket fire was intended to put fear into civilian trespassers but with no guidance systems the charge of wilful killing could not be made out. km
I'll have to search for the link again;
...but it was part of the compromise that Pres. Carter had worked out with the the Palestinians; He'd reasoned with them that.. (as carp wisely suggested) killing people was only getting NEGATIVE Attention, and if they couldn't be dissuaded from acts of violence to gain worldwide attention, then at least they should stop extreme acts, such as suicide bombings of restaurants and buses etc. >THEY HAVE<
The unguided missiles are designed to disrupt life for the Israeli's as much as possible, with a minimum of deaths... (although as we've seen accidents do happen) at least until Israel recognizes THEIR 'right to exist' and the Peace process finally moves toward the long sought after Two State Solution with secure borders for BOTH States.
_________________________ . "...or am I a butterfly dreaming she's a woman?"
