Nagromme
Loc: USA
Long story short: my Air crashed and won't boot (spinning grey wheel, then shuts back down). It seems I may need to reinstall the OS... so I've decided to just go for Snow Leopard.
Problem: the installation needs 5 GB free, and my HD is full!
I want to delete Unreal Tournament 2004. It's an app package 17GB in size.
Questions:
1. Should I boot up with Cmd-S or Cmd-V? (I think the machine and HD are physically OK.)
2. What's the proper, safe syntax for deleting an entire app package and its contents? (There are spaces in the name FWIW.)
This is an Air with no DVD drive (and getting that plus DiskWarrior would cost $200 and might not even help).
MOST of my stuff is backed up (the vital stuff) but a lot of non-vital but still wanted stuff is currently not. So just wiping the drive is not an option.
Are there any command-line commands that might help me here? (A little cd-ing around tells me my stuff is OK... as near as I can tell. cd and ls are about the extent of my know-how :p ) Dare I try fsck_hfs -r /dev/disk0s2 which I found on macosxhints? Dangerous?
Can I delete the (4, 888) file?
Can I find out what that file is (so I know to restore it from backup)?
Can I use the command line to clone my (corrupt?) drive to a USB, ethernet or airport volume? (I have all 3.) Or at least clone certain files? (DVR recordings, downloaded games I never checked out yet, etc.)
I hope I don't have to try to extract the HD physically from my Air.
(This happened when attempting to update to iTunes 9 as it happens. Or rather, when that hung, I Safe Booted, ran YASU, and then tried again. The update to 9 went fine that time, but when I rebooted the machine wouldn't start--in Safe mode or otherwise.)
#444192 - 09/11/0903:10 PMRe: Boot to command line and delete an app package
[Re: Nagromme]
MacBozo Nut Dood
DW would probably fix it. If you can beg, borrow, or steal a current copy on a bootable external drive, I'd do that. I believe cloning would also copy the bad node structure. DU will clone your drive via the Restore option. I wonder if cloning it to a larger drive would cure it.
#444203 - 09/11/0903:59 PMRe: Boot to command line and delete an app package
[Re: MacBozo]
Nagromme
Loc: USA
I'm in the process of moving 250 GB of archived files from an external HD to Time Capsule (dozens of hours?) and then I can reformat it to boot the Air, back up the less vital stuff, and run DW. Better to spend $100 than $200--at least I won't need the DVD drive.
The process will take all weekend. It's like one of those sliding number puzzles with one block free. I have to keep moving the same huge masses of data around, often wirelessly, to have enough room.
#444267 - 09/12/0912:13 AMRe: Boot to command line and delete an app package
[Re: Nagromme]
dreed2
Can you use the USB 2.0 port to speed things up?
I wish I knew more about Unix commands, but I haven't taken that course at college yet, so can't offer any advice. Keeping fingers crossed that you can save your data, though!
I'm really sad that Apple did away with Firewire on their new MacBooks, because that used to be a lifesaver at times like this.
#444328 - 09/12/0903:27 PMRe: Boot to command line and delete an app package
[Re: ]
Nagromme
Loc: USA
As far as I know, the data is recovered. (Carbon Copy Cloner's log shows only a single file that failed to copy--if I read it right. Nothing important.)
However, I lost the $100 gamble on DiskWarrior. The drive cannot be repaired. DW reports physical damage even though the SMART status is OK. Should I trust that?
So the next (expensive) question is: where can I buy a replacement 80 GB HD for a first-gen Air? (I know they're a more obscure kind than later Airs: they use a ZIF connection of some kind.) What kind of drive should I even be searching for? Info is surprisingly scarce. (I found takeapart instructions though.)
I'd even consider an SSD if the cost wasn't much different, but I doubt that.
Did DW give the warning "speed inhibited by disk malfunction?" That almost always means hardware problems, only one time that I saw that did repartitioning take care of it, the rest were actually bad.
Not sure about the SSDs. I'll check but I'm sure they're much more.
