That is pretty slick, it's like having a real window instead of a screen. I especially like the beach and the surf dude. Put his rear in Dinos and I'll bite.
#426689 - 05/01/0912:03 PMRe: A most excellent screensaver and more!
[Re: polymerase]
MacGizmo
Moderator
Loc: Arizona
You can do the same thing for free with any movie file you want... a quick search at MacUpdate or Google will show you the way.
That being said, I've tried it - found it to be a resource hog, and quickly disabled it. Keep in mind that I'm working on large image files and often have the entire Adobe Creative Suite open all the time, so the average Web surfer, emailer and offic app user probably won't have an issue with speed hit.
Very nice app, and a great idea though.
#426829 - 05/02/0902:10 PMRe: A most excellent screensaver and more!
[Re: FSM]
Mac007
Master of the Universe
Loc: MO, USA
I checked the ram and cpu usage and then turned it off and saw a change in ram usage. I tried it several more times and saw no change from what I was using before I installed it. Of course I have 8 gigs installed so maybe that's why it doesn't affect me. Oh well I like it as it's very restful. If it's a ram hog for others then they should either remove it or get more ram. Of course if it doesn't improve your user experience by all means feel free to discard it. I just thought some folks might like it.
"It is better to light one candle than to curse the darkness."
#426830 - 05/02/0902:14 PMI like em all!
[Re: Lea]
Mac007
Loc: MO, USA
I think I'm addicted to this. I like the motion and the sound of the surf, rain, and wind on the different ones. It just makes me mellow. I turn it off and it's just too quiet.
Edited by Mac007 (05/02/0902:15 PM) Edit Reason: Che Quevera spoke to me through the neighbors dog!!!
The kind of work I do, there's no way I could have the desktops in the background. Besides, I'd probably enjoy them too much and never get anything done. But, I agree, they are amazing.
