#420685 - 03/24/0911:30 AMRe: Know-alls get it wrong, again...
[Re: keymaker]
six_of_one
Pool Bar
Loc: Alexandria, VA
Your links prove only that too many people are dying of colonic cancer
Your stated nothing was being done or funded. This is patently false.
I didn't put a percentage on colonic cancer survival rates
You stated "the survival rate would be more than the 20% success rate of IVF". The links I provided indicate rates are already well above that figure, so that statement was incorrect as well.
#420700 - 03/24/0901:27 PMRe: Know-alls get it wrong, again...
[Re: six_of_one]
keymaker
I invented modding!
False if you take it literally, true if you read it figuratively to the effect that 'nothing sufficient' is being done. If tens of thousands of sufferers are dying for want of sufficient screening or drugs then that's quite obviously of greater urgency than mere lifestyle treatments - important though they may be in isolation.
My comment had nothing to do with existing survival rates among sufferers of colonic cancer - that's your misreading of it. Current death rates could be cut in half so, yes, a 50 per cent success rate in the threatened group would be greater than a 20 per cent success rate among the lifestyle group.
#420717 - 03/24/0902:54 PMRe: Know-alls get it wrong, again...
[Re: yoyo52]
keymaker
I invented modding!
Told you the ol' noggin would go spinning.
Noggin? Spinning? Ph...
Spinning's got nothing to do with it, mate - my posts are all based upon reasonable assertions of fact - which is rather inconvenient for you of course.
