#413256 - 02/08/0907:34 AM"You need to restart your computer.
cope
I got this...
Loc: Central Florida
Hold down the Power button for several seconds or press the restart button."
This message, in English, French, German and what appears to be Japanese come up in a gray box on my daughters G4 iBook when she tries to start it. Once it appears (after her desktop loads and dims out) no keys or the trackpad operate. It sure doesn't look or sound like an Apple kind of message at all but who knows.
She has "misplaced" her system disks so a CD start-up is not feasible at this time.
#413258 - 02/08/0907:47 AMRe: "You need to restart your computer.
[Re: cope]
Svend
Científico aficionado
Loc: América del Norte
That's the mac version of the blue screen of death. Usually a hardware problem.
Try reseating the RAM. Maybe the RAM chips became loose. While the power is off (battery removed) pull out the RAM stick and put it back in. If there is an airport card pull that out and put it back in. These are just general instructions, I'm not familiar with a G4 iBook and it's internals (if there are RAM chips that can be removed, etc.)
_________________________ Yo soy un hombre sincero de los alpes suecos. Con los pobres de la tierra, quiero yo mi suerte echar.
I haven't had a kernel panic recently, but if I remember correctly, I used one or both of these options:
Reboot holding Command + S to start in Single User Mode Type "/sbin/fsck -fy" without "", then hit Return Once your drive is checked, type "reboot" without "", then hit Return
Reboot holding Command + Option + O = F to start in Open Firmware Mode Type "reset-nvram" without "", then hit Return Type "reset-all" without "", then hit Return
