Has anyone else experienced this since the last iPhone OS update? I put my phone down with the home screen showing, and a few seconds later it suddenly jumps into iPod player mode, all by itself.
#413096 - 02/07/0908:38 AMRe: Jumping into iPod
[Re: padmavyuha]
Nagromme
Loc: USA
No. Anything good playing?
Was any cable connected? Maybe it received an erroneous "play" signal from the dock connector?
Or maybe you had accidentally double-clicked Home, which might be set to launch the iPod? There could have been some data-loading delay that made it not happen at first.
