Thanks for telling me more than one Inspector can be open. That might never have occurred to me but is extremely helpful. There are iWork08 workshops ten minutes away. I think I need to check one out so I can see an expert in action. I bet they would have two open also.
Hey thanks. "That Apple does not make that chore difficult with restrictive serial numbers that call in and register themselves is something that I want to reward and keep on rewarding."
"The clown funnied his way to the big top." Isn't that intransitive since the prepositional phrase "to the top" acts as an adverb and needs to be there? Or something like that. Good grief I actually liked diagramming sentences in grade school but that might have been the last time i had ever thought of it.
#407052 - 01/10/0903:02 PMRe: Pages, OK, I changed my mind
[Re: polymerase]
The direct object is "his way," not the phrase, which you've correctly identified as an adverbial prepositional phrase. If I could imbed ( ) a sound file, I'd put in this one.
For some reason I liked prepositional phrases. Maybe because they were easy to spot but then they were so devious and could trick you. I also could have had a wicked crush on my english teacher who taught me them but she was extremely hot and drove a trike motorcycle. I would diagram her sentences anytime anywhere, on the floor, under the tree, in the ...
